Old 03-14-2015, 07:00 PM   #1
yoshi
yoshi's Avatar
Heater hoses through bulkhead
Where the heater hoses go through the bulkhead, what have you used to protect the hoses from being cut by the steel & where did you get it? Thanks
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 03-14-2015, 07:23 PM   #2
Donaldo
Re: Heater hoses through bulkhead
Are you using an original heater ?
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 03-14-2015, 07:42 PM   #3
yoshi
yoshi's Avatar
No I'm not using the original heater, I've got one from a mini. I do have a large hole about 2" & 4 smaller holes about 1/2" on the driver's side where the brake booster used to be
yoshi's 49 project
Old 03-14-2015, 10:06 PM   #4
Donaldo
sounds to me like you might want to look through the catalogs for Bulkhead Heater fittings.
Thanks, Don
Old 03-15-2015, 08:55 AM   #5
Chevy-49
Chevy-49's Avatar
Used bulkhead fitting from t7 design, wanted to have an clean firewall,
mounted the fitting in the inner to outer cowl panel.
Hoses thru inner fender.
Gr Richard
Chevy-49 is offline   Reply With Quote
Old 03-15-2015, 02:24 PM   #6
OrrieG
OrrieG's Avatar
I used bulkhead fitting to run them into the fenderwell, then grommets thru the inner fender and a support bracket on the wheel side of the inner fender. Was the easiest to get around VA horseshoe hardlines under the dash and battery box.
OrrieG is offline   Reply With Quote
