Old 03-14-2015, 07:47 PM   #1
blazercrazy70
blazercrazy70's Avatar
Do you need different motor mounts with dirty dingo adapters
I am a bit confused if I use the dirty dingo adapter plates can I use the stock motor mounts or do I need something else
blazercrazy70 is offline   Reply With Quote
Old 03-14-2015, 09:48 PM   #2
mattcrp1
mattcrp1's Avatar
Re: Do you need different motor mounts with dirty dingo adapters
I used the factory motor mounts for my DD sliders in my '76.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-15-2015, 09:07 AM   #3
Willie Makeit
Willie Makeit's Avatar
used DD sliders with stock towers in my '67 ... you won't be able to mount the AC compressor in the lower position with this set up though.
Willie Makeit is offline   Reply With Quote
Old 03-21-2015, 01:08 AM   #4
blazercrazy70
did you exhaust manifolds or headers
Old 03-21-2015, 02:01 PM   #5
mattcrp1
mattcrp1's Avatar
Same here I had to remove the a/c compressor. I am using TBSS manifolds in my 76.
IG mattcrp1
Old 03-21-2015, 06:14 PM   #6
H20cooled
I bought a set of 73+ frame mounts from Ebay, cleaned then up, repainted them, and installed new rubber. They worked great.
H20cooled is offline   Reply With Quote
Old 03-23-2015, 08:57 AM   #7
Willie Makeit
not sure if that question was for me, but I used the Doug Thorley headers.
Old 03-25-2015, 03:13 AM   #8
l92powered77
Yes you can use the stock clam shell motor mounts sold at any auto parts store when using the dirty dingo motor mounts.I am using the same mounts in my 77 and i just bought two v8 version clam shell mounts for my motor for like 7 dollars a piece at oreilys.
Happy building man! If you have any questions about what the dirty dingo mounts are compatible with just give them a call and ask to speak to BRENT,hes the owner and maker of all parts made and sold at dirty dingo hes really knowledgeable and totally cool.
l92powered77 is offline   Reply With Quote
Old 03-25-2015, 09:38 AM   #9
solidaxel
solidaxel's Avatar
Same here for my 78, and the drive shaft, and shift linkage is in the same location
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-16-2015, 11:33 PM   #10
l92powered77
Lightbulb Re: Do you need different motor mounts with dirty dingo adapters
To answer the question.
You can use your stock motor mounts the clam shell ones when using the dirty dingo mounts. I have a 2 wheel drive 77 and i had no issues.
