03-14-2015, 08:24 PM | #1 |
Brake bleeding and red brake light
Red brake light came on when driving home from the body shop a few weeks ago on my 72. Found the master cylinder rear reservoir completely dry. Filled it up, started the engine and the light was out. Came back two days later and light came on again. Went ahead and bled the rear brakes today using a vacuum pump brake bleeder. I ran about 4 oz. through the left cylinder and about 8 oz through the right. Made sure the master cylinder did not go dry. Did not get a clear stream but directions indicate small bubbles caused by connections not being air tight can occur. That seemed to be the case. Red light still is on. I took a test drive around the block and I have a right rear brake that is locking up with moderate pedal pressure. Any suggestions before I let my mechanic loose on it?
03-14-2015, 08:46 PM | #2 |
Re: Brake bleeding and red brake light
You need to find and fix the leak first.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
03-14-2015, 08:54 PM | #3 |
You need to bench bleed the MC if one of the reservoir went dry then it needs to be done make sure there are zero leaks of any kind hopes this helps.
03-14-2015, 09:05 PM | #4 |
Sounds like the wheel cylinder is leaking on the brake drum,( the one locking up) hense the fluid loss. As far as the light, it sounds like metering valve pin on the end of the combination valve has to be held in while adjusting the front disc brakes. that sets the light. I think the rear res goes to the front brakes..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
03-14-2015, 09:07 PM | #5 |
Thanks for the help.
03-14-2015, 09:21 PM | #6 | |
Then vacuum bleed it again and you should be OK. |
03-14-2015, 10:55 PM | #7 | |
20' Daredevil (Ret)
03-15-2015, 12:04 AM | #8 |
Again, many thanks for taking the time to respond.
