03-15-2015, 12:24 AM | #1 |
Engine Tick
Hey Guys, I have a 1972 C10 and I have an engine in it with less than 2K miles and I bought the engine and put it in my truck about 6 months ago. It is a 350 Big Block with a RV Cam in it. I just, within the last week, started hearing a tick on one of the passenger side cylinders. I have done a little bit of research and I am pretty sure that it is just a lose rocker arm. If that is the case, how difficult is it to take off the valve cover, and then tighten the rocker arm, and then put the valve cover back on with all the seals and everything. If you have any experience or anything you ran into when you did something like that, any advice would be greatly appreciated. Thanks!!
03-15-2015, 01:12 AM | #2 | |
Re: Engine Tick
Some of the other guys will weigh in clean up some of my info I'm sure. All good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
03-15-2015, 01:15 AM | #3 |
C/10 junkie
Re: Engine Tick
350 big block
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
03-15-2015, 01:16 AM | #4 |
Re: Engine Tick
Awesome thanks for the reply, but is there any special trick or technique to put the valve cover back on with the gasket?
03-15-2015, 01:24 AM | #5 |
Re: Engine Tick
03-15-2015, 01:41 AM | #6 |
C/10 junkie
Re: Engine Tick
Haha it's all good. Typo
03-15-2015, 09:22 AM | #7 |
Re: Engine Tick
Here's a wiki on adjusting valves.
http://www.crankshaftcoalition.com/w...raulic_lifters |
03-15-2015, 01:08 PM | #8 |
Re: Engine Tick
350 big block ... would that be a Pontiac?
Follow the instructions laid out above and hopefully your problem will be solved. Be sure to look for worn parts, notches cut into the side of rocker studs and the like.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
