Old 03-15-2015, 07:21 AM   #1
7tee
7tee's Avatar
T-5 shifters
NEW HERE and what a great forum this is...
'70 red stepper, 350, mild cam and T-5 transmission...
Ok, so has anyone converted to a short throw shifter (Hurst) on a Borg Warner T-5 or are there any other options as my shifter span now is about 6" between gears... thanks ed
7tee is offline   Reply With Quote
Old 03-15-2015, 08:25 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: T-5 shifters
I can't help on the shifter but welcome to the board. Sometimes things can be a little slow around here on Sundays...
LockDoc
Leon
Old 03-15-2015, 11:13 AM   #3
Wrenchbender Ret
Re: T-5 shifters
I use the Hurst for Camero T-5. It comes with a short handle shifter that mounts different from the S-10 but I modify the S-10 handle to work.
Wrenchbender Ret is offline   Reply With Quote
Old 03-15-2015, 11:54 AM   #4
7tee
7tee's Avatar
Re: T-5 shifters
The hurst billet short throw shifter base that mounts on top of T-5 (closer shift pattern than factory) listed on e-bay is about $250.00. Hopefully that would decrease my shift throw pattern from around 6" (with 20" shifter arm) to about 4". But that's $250, are there any other ideas?
Old 03-15-2015, 12:43 PM   #5
tcrist
Re: T-5 shifters
I used the PRO 5.0 shifter on my Cobra Replica. Not sure if they are the same as used on GM cars as other manufactures.
http://www.cjponyparts.com/pro-5-0-m...3-2001/p/MS02/
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
Old 03-15-2015, 12:58 PM   #6
hugger6933
Re: T-5 shifters
I planned to build a hybridT5 for my project dirt cheap as soon as it come off the rotisserie. I have A Camaro T-5 and A S-10 T-5 but the one from the Camaro has a short throw and the gears seam to be only a couple inches away from each other with that shifter. Jim
hugger6933 is offline   Reply With Quote
Old 03-15-2015, 01:30 PM   #7
Mike C
Mike C's Avatar
Re: T-5 shifters
The GM V8 T5 uses a different shifter than the Ford T5. The Nissan (280zx turbo) T5 uses the same shifter as the Ford. FWIW.
And they are worth whatever they cost the OEM shifter is so wonky.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-15-2015, 06:54 PM   #8
7tee
7tee's Avatar
Re: T-5 shifters
Yes I might have to just bite the bullet and get the short throw, thanks for all the comments...
