Custom radio delete plate
I couldn't find an original 514 red radio delete plate, so I decide to make one myself. Not exactly like original, but I like this chevy design better. I have less than an hour in it and that includes making the hammer form.
![]() I still need to make the clips to hold it on, but that's easy enough. ![]()
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
Re: Custom radio delete plate
I like mine better. Not only is it an Ashtray and Radio delete plate, but it's invisible.
#3 | |
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Looks like a great idea, good job...
I think your dash pad 3 gauge pod is trick! Did you fabricate yourself? Would love to incorporate something like that on my truck!
John San Diego, CA 1969 C-10 “ A person who never made a mistake, never tried anything new.” Albert Einstein |
![]() Join Date: May 2014
Not a fan of it. Or the dash pad gauges or the cluster bezel or the glovebox door. I like these old trucks because of the original old things. Skewing too far away from the original look just isn't my taste. My aftermarket steering wheel bugs my but I needed a smaller wheel so I could be more comfortable in the cab.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
#10 | |
I did mine this way so it would look different from all of those stock trucks out there, knowing all the while that there would be some who would really criticize it because it didn't look the way they believe a truck should look. I really don't care about those guys. I built my truck the way I wanted it not the way somebody else likes them. It's your truck. Build YOUR truck, not someone else's! |
Looked hi and low for a original plate in decent condition with no luck so bought this custom ball milled plate and fit very well in my 68.
#13 |
RAT1968 '68 Cab/'71 Parts
I couldn't find anything as cool as nicksdiner's. And, I don't have the talent to do what Fitz did.
If I could have found a delete it would have looked like the first pic. Instead, I found a decent (cosmetic) radio that was fubarred. Cut the back off, slid it in.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#14 |
I appreciate it, I really like the way it looks. Search E gauge plus radio delete and it will pop up. They even have a matching ashtray insert which looks good.
#15 | |
you don't say.
#16 | |
#17 |
65, Nicely done! My radio was gone when I bought it and the original hole had been hogged out a bit. I've just been living with it cause it's not high on my list. I think rather than going to the shop and machining one I'm gonna try to do something similar.
Good work, Dan |
#18 |
I finally got a chance today to make the two mounting clips.
![]() I wanted to make sure it fit. Now I can use that special order can of 514 GM red and paint it. ![]()
#19 |
![]() Join Date: Jun 2012
I dig it, simple and effective. Someone's arm put some time on that door huh
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
#20 |
Cruzin
I like it also, less is more
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#21 |
65standard nice work on everything you do. Where do you get your buzz bomb gm colored paint? Im gonna need some soon but olive color.
#22 |
I like it. Someone should sell these for those of us who bought trucks with the radio opening cut out for a modern stereo. I will eventually get the patch panel for the stock stereo but until then it would cover the gaping hole in the dash.
#23 | |
Cost like $20 for a spray can.
#24 |
Painted and reinstalled.
#25 |
Oh, by the way, I didn't use my special order can of GM 514 red. I used regular Chevrolet orange-red engine enamel. It is a perfect match, cheap and easy to find anywhere.
