03-15-2015, 04:30 PM | #1 |
Cam change in truck - removing front end
I was curious what people have done to remove the front sheet metal from the truck, in order to perform a cam change. Is it possible to remove the front end (fenders, core support, grill etc) as one piece? Or am I better off removing the radiator, support, and grill in separate pieces?
Any help or advice would be greatly appreciated - I tried searching but couldn't find much information. Thanks! -ZP |
03-15-2015, 05:22 PM | #2 |
Re: Cam change in truck - removing front end
On my small block I just pulled the radiator and it came right out. Did not need to pull anything else.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-15-2015, 05:25 PM | #3 |
03-16-2015, 01:28 AM | #4 |
I can also confirm that a radiator pull is all that's needed. Thread a long bolt into the end of the camshaft so you can get it into the block smoother/easier. If space gets tight you can reach your hand through the grill and grab the bolt still to guide the camshaft in. Once in remove the bolt.
03-16-2015, 04:43 AM | #5 |
x2, on the radiator,
may have to tilt the condenser up for a A/C car..
JJ 71 SWB 360 Th400 4.56 |
03-16-2015, 08:40 AM | #6 |
I don't know which engine you are working on but some you have to be careful not to knock the plug behind it loose when putting on the cam gear.
03-16-2015, 08:56 AM | #7 |
03-16-2015, 10:26 AM | #8 |
03-16-2015, 11:01 AM | #9 |
This is actually good to know. Between the overly lumpy solid lifter cam the PO installed and the likelihood that the heads on my 400 are not compatible with unleaded fuel and possibly toast, not having to pull the nose to do some top end work is a relief.
03-16-2015, 04:28 PM | #10 |
I had to pull off my grill.
