Old 03-15-2015, 09:52 PM   #1
whitley7
Newbie Exhast Question - 63 w/350
Hello All, I recently bought a 63 c10 fleetside longbed. It had no motor, trans, radiator or drive shaft. The previous owner had converted the front to disk brakes. I bought a 350 and found some procomp ceramic coated mid-length headers on craigslist and went to install the motor this weekend only to find that the headers were hitting the chassis on broth sides and preventing the motor from sitting on the perches. after about two hours of lifting, prying and shoving I finally gave up and removed the headers. The motor is now bolted in and I need some advice about finding an exhaust manifold that will work with my truck and 350. I have looked at the rams horn type, it seems they would dump above the chassis just past the perches and there would still be a problem getting a pipe up to them to connect. Any advice would be greatly appreciated. Thanks in advance.
whitley7 is offline   Reply With Quote
Old 03-19-2015, 01:22 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: Newbie Exhast Question - 63 w/350
Put one of these in and forget your troubles.
Headers fit with ease on these!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
