Old 03-16-2015, 12:08 AM   #1
Mmorgan32
Mmorgan32's Avatar
1970 c20
I have a 1970 c20 camper special I want to lower it by removing a couple leafs and putting on longer shackles. My question is where can I get shorter u bolts the stock ones will be to long
Mmorgan32 is offline   Reply With Quote
Old 03-16-2015, 09:24 AM   #2
c20pickup
Re: 1970 c20
A local shop can bend new ones up while you wait, maybe look into some machine shops, suspension, or welding shops
c20pickup is offline   Reply With Quote
Old 03-16-2015, 12:52 PM   #3
Mmorgan32
Mmorgan32's Avatar
Re: 1970 c20
I'll do that. Thanks
Old 03-16-2015, 02:57 PM   #4
hamjet
hamjet's Avatar
Re: 1970 c20
Or you can just add a block on top of the springs to make up for the leafs you took out..if you put the block under the springs you won't have to add shackles.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 03-16-2015, 09:38 PM   #5
Mmorgan32
Mmorgan32's Avatar
Re: 1970 c20
What about the front do they have stiffer springs than a c10? Should I just cut them
