Old 03-16-2015, 12:17 PM   #1
koolkat269
Frame rails
Don't have time to look for it but was wondering if 2wd 1/2 ton frame rails are the same as 4wd 3/4 ton for the 80's model.
koolkat269 is offline   Reply With Quote
Old 03-16-2015, 04:30 PM   #2
crashz
crashz's Avatar
Re: Frame rails
I don't think so.
There was a great post with a GM frame chart here, but I can't find it. Anyway it related GVWR and series with bending moment. There was a lot of factors, but mostly relating to section modulus, and for those series (as dimensions are basically the same for long bed rails) the thickness of the steel was the difference. There was some crossover, but very little. IE- its possible that a heavy 1/2 frame rail would be the same as a light duty 3/4 rail, but it would need to be referenced by serial number.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 03-16-2015, 11:46 PM   #3
Slammed84
Slammed84's Avatar
Re: Frame rails
Originally Posted by crashz View Post
I don't think so.
So is that what a heavy half is? Just a beefier frame but 1/2 ton suspension? What is the Big 10?
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 03-17-2015, 01:56 AM   #4
andrewmp6
Re: Frame rails
The look a like but not sure on the frame thickness if that matter or not.Why do you ask?Is your frame rotted out or trying to do a 4x4 swap by swapping the bodies?
andrewmp6 is offline   Reply With Quote
Old 03-17-2015, 06:15 AM   #5
GM72K10
Next!
GM72K10's Avatar
Re: Frame rails
Thickness is different
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 03-17-2015, 07:06 AM   #6
koolkat269
Re: Frame rails
Actually I have a 86 roller that I am using the suspension and rear-end in my 64 and a kid at work has a 3/4 ton 4x4 that has a cracked frame
Old 03-17-2015, 07:29 AM   #7
Keith Seymore
Keith Seymore's Avatar
Re: Frame rails
Other way around.
Big 10/Heavy Half use the 1/2 ton frame but get heavier duty springs/leaf spring packs.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
