Old 03-16-2015, 12:25 PM   #1
ChevEE
ChevEE's Avatar
Column Shift Indicator Help
I have a 1970 C10 with a TH400 and non-tilt column.
I need to replace the Indicator Pointer Housing and found that. I also noticed that the letters are practically wore off on the lens. However, I cannot find a lens listed for my truck anywhere. Below is the LMC catalog page. Does the 1970 model matter if it has tilt? I have checked a number of retailers and find similar listings.
Another possible option, has anyone tried painting the letters back on the lens? Seems like it needs to be a special paint.
1970 C-10 lwb, 307 V8, THM-400
1998 Camaro Z28, LS1, T-56 6 speed manual (Daily driver)
ChevEE is offline   Reply With Quote
Old 03-16-2015, 12:59 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: Column Shift Indicator Help
I have run into the same thing. My 70 needs the little pointer. I got the one shown from LMC and it just wasn't right. As I recall, the ears that hold it to the column were too narrow. It then broke in a short time.
I see them for the tilts and other years but the 69-70 w/o tilt........... ARGH You may want to look through the for sale area.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-16-2015, 01:05 PM   #3
70shortfleet
70shortfleet's Avatar
Do not use the tilt lens, it is only for tilt columns
70shortfleet is offline   Reply With Quote
Old 03-16-2015, 01:59 PM   #4
ChevEE
ChevEE's Avatar
Longhorm70, thanks for the heads up on the pointer.
Anyone know if the three speed listings here would work?
http://www.ididitinc.com/accessories...icators_Acc-17
They look right in the picture.
Old 03-16-2015, 02:02 PM   #5
Longhorn 70
DEFINITELY worth contacting them to see if they fit factory columns.
Old 03-16-2015, 02:28 PM   #6
ChevEE
ChevEE's Avatar
They list NPD as a dealer of their products, and I happen to work 5 minutes from the NPD in Charlotte so I will take my parts in and see if we can't get to the bottom of this. I will share what I find out.
Old 03-16-2015, 02:51 PM   #7
Wrenchbender Ret
It seems #6 is what you want. I have a whole set in good condition if you can't find a new one.
Wrenchbender Ret is offline   Reply With Quote
Old 03-16-2015, 03:25 PM   #8
Longhorn 70
The reason I didn't want to use their pointer is it uses doublesided tape to keep it on.
