Old 03-16-2015, 01:19 PM   #1
rigon4
rigon4's Avatar
where to find a transmission ratio adapter
I'm looking for a adapter for my truck ac part number 1565208 ratio 1:0.833 no luck finding it can someone give me some places to look I Googled it and checked eBay with no luck thanks
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 03-16-2015, 02:04 PM   #2
geezer#99
geezer#99's Avatar
Re: where to find a transmission ratio adapter
http://www.transmissioncenter.net/sp...n_______va.htm
geezer#99 is online now   Reply With Quote
Old 03-16-2015, 08:39 PM   #3
wideopen1967
wideopen1967's Avatar
http://www.texasindustrialelectric.c...on_Adapter.asp
wideopen1967 is offline   Reply With Quote
Old 03-16-2015, 11:13 PM   #4
rich weyand
rich weyand's Avatar
I have used both of the vendors listed above with no issues.
I can't find the AC Delco part either, which means getting an aftermarket part.
Be careful figuring percentages. .833 is 16.7% less than 1, but 1 is 20% more than .833. GM lists ratio as the speedometer side, so .833 out to the speedometer for 1.000 in from the xfer case. So you should be reading 20% high on speed (reading 60 mph at an actual of 50) to need a 17% step-down adapter.
The first vendor listed above has a 17% slow-down adapter. (From 60 down to 50 is 17% slower.)
The other option is ACDelco #3950352, which is 1:.8241. This will be 1% low, or 1/2 mph at 50. I couldn't find one of those either.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 03-17-2015, 03:59 PM   #5
RedRoad
RedRoad's Avatar
Would these adapters be the same for 4x4? Im running a NP205 T/C and the speedo reads 7mph slower due to larger tires, anyone have a part number?
RedRoad is offline   Reply With Quote
Old 03-17-2015, 04:48 PM   #6
RIDE-RED 350r
RIDE-RED 350r's Avatar
Wish mine was only 7mph slow... Reading about 48 I'm actually going 60.
I was kicking around here yesterday and saw another speedo ratio adapter thread... Gave myself a brain-ache trying to figure out the math to determine what % to speed up my guage....
I give up... Just read the tach! LOL!
Who needs a Hemi when ya got a Chevy!
RIDE-RED 350r is offline   Reply With Quote
Old 03-17-2015, 05:49 PM   #7
hatzie
Moderator
hatzie's Avatar
I put together a spreadsheet to take some of the pain out of it. You can find it on the manual page.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-17-2015, 05:51 PM   #8
biggsteve97
Speedometer shops can build them.
Thank a Veteran. They have sacrificed more than you will ever know!
2003 Chevy Z71 Tahoe 190,500 miles
2002 Chevy Silverado 1500 4x4 230,000 miles
1987 custom built Silverado 4x4 435,764 miles
1985 K5 Blazer 396 bb 4x4 project
1982 K5 Blazer Silverado 4x4 519,348 miles
biggsteve97 is offline   Reply With Quote
Old 03-17-2015, 06:17 PM   #9
RIDE-RED 350r
I'll check it out Hatzie. Thanks!
Woops... Downloaded the Apache files and I couldn't open it due to "sharing violation"....
Old 03-17-2015, 06:54 PM   #10
RIDE-RED 350r
Just got it figured out and got the spreadsheet open... WOW that's confusing! Never used a spreadsheet before.
Old 03-17-2015, 08:38 PM   #11
rich weyand
To figure a new ratio, and look up the part number, I need 1) the speed indicated, 2) the actual speed, and 3) the ratio of the adapter that is already on there. The existing adapter should have the ratio stamped on the housing.
An alternative to the speed indicated and actual speed is to drive 10 mile markers on the Interstate somewhere, recording the odometer reading (to tenths) at both ends, then subtract them. You will come up with something like 10.7 or 9.5.
Anyway, give me that info and I will calculate it and look it up.
Rich Weyand
1978 K10 RCSB DD.
Old 03-19-2015, 08:56 AM   #12
rigon4
rigon4's Avatar
I got mine working for about 50 miles but then stopped and the Speedo was off also so what ratio would I need my GPS said I was going 50 the trucks Speedo said 56 and that was with the 1:833 adapter
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 03-19-2015, 10:11 AM   #13
rich weyand
To get it to display 50/56 of what it is displaying now, you need a 50/56 step-down, or something like 1:.893. You already have 1:.833 on there, so to get one ratio adapter that incorporates what you have plus the additional you need, that is .893 * .833 = .744. So you need a 25.6% slow-down adapter.
Closest period GM part is 3952220, at .7333. This will be about 1% slower than what you need, so will show 49.5 at 50. This was a common adapter for Corvette's with low rear-end ratios, like 4.56:1. I found a used one here:
http://www.parts123.com/parts123/yb....5Z50000050n~~~
That same exact ratio is also available here as "slow down 26.7%":
Rich Weyand
1978 K10 RCSB DD.
Old 03-19-2015, 05:40 PM   #14
11555wally
Hi Rich. Where do you find the ratio stamped? Is it on the little box between the transmission and the speedo cable? Didn't see anything on mine but I could take another look.
11555wally is offline   Reply With Quote
Old 03-19-2015, 05:52 PM   #15
rich weyand
The little box between the transmission and the speedo cable is probably a ratio adapter. That should have a ratio stamped on it if it is a GM/AC Delco item.
I think they normally did the speedometer ratios in the drive and driven gears of the transmission without ratio adapters in the C trucks. In the K trucks, there were fewer ratios available, and so they had factory speedo ratio adapters.
Rich Weyand
1978 K10 RCSB DD.
Old 03-19-2015, 06:28 PM   #16
11555wally
I'll get a better look at it tomorrow. I'm sure the truck didn't come with the rally wheels and big tires. It's an 86 Custom Deluxe. I know the engine was originally a V-6 but now is a 305. I checked the speedometer this morning against my GPS and when the speedometer said 65 the GPS said exactly 60. Down and around 25 there didn't seem to be any difference. Thanks for the info as usual.
Old 03-19-2015, 11:08 PM   #17
rich weyand
So it is probably an aftermarket ratio adapter to correct for some changes along the way. Best is to take that off and put the cable directly into the tranny and see what you have. While you do that note the color of the driven gear the cable plugs into. They are color coded, and a new gear is cheap and easy to replace. On a transfer case, there are fewer choices, and the driven gears are expensive and unobtainable, so there you normally go with the adapter.
Rich Weyand
1978 K10 RCSB DD.
