Cab floor brake hole
I cut the extra piece of metal that the brake arm went through. You normally put a piece of felt inbetween the 2 piece's of metal or the gap. Wondering if you guy's did the same and used some type of grommet or if I should weld that piece back on to the floor
Re: Cab floor brake hole
I was just planning on running the felt on my brake and clutch pedal. What ever you use has to let the pedals slide through it smoothly and easily.
I've also found that you normally don't get the pedal located perfectly in the hole the first try.
Do you think I should weld that piece back on so I can use the felt?
