03-16-2015, 02:23 PM | #1 |
LS Swap Air Cleaner...
So for those of you who have done LS swaps, preferably with car intake, what did you use for your cold air intake?
03-16-2015, 03:24 PM | #2 |
Re: LS Swap Air Cleaner...
on my 55 i used about 8' of aluminum piping from the turbo with the filter mounted to that
on a serious note there are plenty of options, you can piece your own together with components from siliconeintakes.com or you can try and make something work with a kit from k&n or the like thats vehicle specific. On my DD (94 Tahoe) i bought a 99-07 gmc truck CAI from spectre then hacked it up to work. |
03-16-2015, 10:50 PM | #3 |
Get a k&n and a cheap Silverado intake for the tube off eBay, only 4" I could find. I used 2
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
03-16-2015, 10:53 PM | #4 |
Here is a sneak peak of what I've been working on, you can see the intake in this shot
03-18-2015, 10:20 PM | #5 |
This is what I used.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU Last edited by trkfrk; 03-18-2015 at 10:29 PM. |
03-18-2015, 10:27 PM | #6 |
Engine with intake pic. I ended up buying more couplers to replace the red/orange for black on Amazon. I also fabricated my air intake bracket out of some 1"X1/8" aluminum flat bar to help support everything.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
03-18-2015, 10:27 PM | #7 |
I used that same one x2 I cut one to fit, and don't try using that cheap filter, get a reliable k&n
03-18-2015, 10:35 PM | #8 |
So you scraped the Silverado intake tube? Your engine looks nice
03-18-2015, 10:48 PM | #9 |
That's 2 Silverado tubes, but I cut one into 3 pieces so that I could extend over behind the headlight, I have some coil covers done too just need to paint them then it will look like I want. Also have red to cover all the hoses. Many it will be done next week for new pics. Thanks for the compliment...
03-18-2015, 11:17 PM | #10 |
If you changed the color of the rubber and A/C, what parts did you use?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
03-18-2015, 11:27 PM | #11 |
03-18-2015, 11:29 PM | #12 |
,,,,,,,,,,,,,,,,,,,,,,,,,Ooops!
