Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 03-16-2015, 05:53 PM   #1
NONHOG
NONHOG's Avatar
Windows leak, roof leaks.... what next?
So my shop is an ongoing project. Its not too old. Now the dang roof is leaking. And........... the rear windows are leaking. I'm thinking with the wind and heavy rain it was pushing in past the J channel on the rear windows?
The roof I really don't know. Once it gets dry I'll crawl up there and have a look-see. It leaked a few months ago and I figured it was due to a fir needle dam. It stopped but now was leaking worse. We did have a couple inches of rain over the weekend. Regardless it shouldn't leak!
Not yet sure how to attack this. Been years and never leaked before. That I recall. Except when it was snowing sideways it pushed in. I added closure strips and some great stuff and ended that. I have to wonder how a pro would handle this. If my builder was around I'd ask them. They are not.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 03-16-2015, 05:57 PM   #2
NONHOG
NONHOG's Avatar
Re: Windows leak, roof leaks.... what next?
Last photo is to show flashing style that is in question on rear windows.
But they are 20' up.
More pictures (rear windows) on here.... http://67-72chevytrucks.com/vboard/s...d.php?t=266634
Good sealer recommendation's? Or steer clear of sealers?
My head hurts thinking about it.
Old 03-16-2015, 07:16 PM   #3
cableguy0
Caulk all the joints. A good clear outdoor silicone will get the job done. All the flashing in the world wont do a thing if the joints aren't sealed.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-16-2015, 08:50 PM   #4
JustLearnin
JustLearnin's Avatar
Try to isolate where the water is coming from, at least from a front of shop to back of shop perspective. With metal roofs the leak may not necessarily be in the same spot as where it's dripping.
I keep going to the exterior photo where the shop roof connects to the rest of the structure. That little valley could be it. Is it leaking in that section of your shop? Otherwise, climb up there when it's dry with some silicone caulk and start caulking screw holes and the like. Good luck!
-- Don (Psalms 27:1)
My '72 Blazer Build Thread
JustLearnin is offline   Reply With Quote
Old 03-17-2015, 12:17 PM   #5
mmiddle
mmiddle's Avatar
The Roof... This looks like a "standing seam" roof.. (No external screws). Generally these are very good as far as leaks are concerned. I would use a colored silicon as close to roof color as possible and seal the joints where the roof lines come together. This is likely where it is actually leaking.
The window trim will be the same way. Add silicon.
Unfortunately, I agree if this was not sealed properly during construction there is little you can do but add more sealer. The mastic tape and silicon was either not put on right during construction or left out all together. Being this is a pole barn it is likely it was never put on at all.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 03-18-2015, 12:06 PM   #6
_Ogre
_Ogre's Avatar
the way those door/window headers are installed, they depend on the roof overhang as flashing
as installed; the door trim is designed to trap water that hits the siding. nothing correct about that install
caulk will have limited effect and you'll need a lot of caulk to fill the trim. cases of caulk.
metal, wood, brick, shingles, horizontal, vertical and diagonal all flash pretty much the same way
any flashing should not depend on caulking to repel water, caulking should be secondary
here's a pretty good flashing manual for metal roofs and siding; go to page 36 for door header flashing
look through the manual and you'll see everything is applied in layers like a roof and requires no caulk
properly installed flashing will also drain any interior condensation that happens on metal siding
luckily it's a metal building and easily deconstructed to install a Z/L flashing above the door/window
any shop that sells the siding will have Z/L flashing, even home depot sells it
shop air compressor timer
Old 03-18-2015, 01:25 PM   #7
NONHOG
NONHOG's Avatar
Pretty sure I got the 'ol standard trim.
Like this.......... https://www.youtube.com/watch?v=-UQG3TB2JRA
Old 03-18-2015, 11:50 PM   #8
NONHOG
NONHOG's Avatar
Snapped a few pics tonight.
Old 03-19-2015, 01:43 AM   #9
dieseldawg142
dieseldawg142's Avatar
your inner standing seam has been cut to clear your fascia board. you want no cuts in your seam, especially at the bottom of a valley, thats where all the rain is heading, good chance thats where the water is going in. take a screwdriver, pry up the metal they have folded around it, & you will find a hole, most likely your point of entry. there is nowhere else on your roof that could let that much water in unless you had a ripped panel or something.
to cure it, slip a piece of metal up UNDER your valley flashing, & down over past the hole, past the seam an inch or so, on TOP.
your metal is cut a little too close to the valley, with all them trees i bet they clog up fast....in a typical pacific northwest rain, your roof is shedding hundreds of gallons every minute, not good to have stuff clogging it's path off the roof.
dont try to caulk it, for the above mentioned reasons, it's only a temp thing, would'nt surprise me if you do find old caulking under there.
dont feel bad, it's ALWAYS the details that leak, but you actually have a quick & simple detail to fix.
seeing how YOU are up there taking the pics, save your money & do it yourself, or if you do call a roofer, dont let them gouge you too bad for something simple...
just some observations, i'm on my 33rd yr in roofing, just down the road from you, why did your contractor not put any underlay under the roof, all the metal manufactors call for it, & it's in most area's up here it's in the building code, Washington's weather is the same here & it would never pass insp. without it. if your heating it too, even if you are'nt, your roof & building will also benefit greatly by having some vents installed.
unless you did the door trim yourself & know exactly how it's done, i wont guess on that. yes, there is a right & proper way it's supposed to be done, but in my experiance, a lot of times when you pull it apart, sadly (for the homeowner) it's not always proper & right....
dieseldawg142 is offline   Reply With Quote
Old 03-19-2015, 02:34 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm curious, was this a metal "buy as built" building like you can order or build yourself? If not, ignore this, but I've wanted to know from someone that used one.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-30-2015, 09:54 PM   #11
swamp rat
swamp rat's Avatar
I cant imagin the roofing contractor wouldn't warrentie the work. The fact that they cut seam should be enough to go after them for the fix and at least file a complaint with the attorney general, that might make them happy to fix it?
Barring that maybe you can use some epoxy like JB weld or something to fill the cut area and make it water tightJ
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-31-2015, 02:26 PM   #12
NONHOG
NONHOG's Avatar
Thanks for the replies guys.
Been busy with other stuff. Cleared needles off roof and its not been leaking.
I'll take a closer look again when dry.
Building is a custom design and the builder is no longer in business.
Just my luck.
I'll update when that time comes.
Old 03-31-2015, 06:00 PM   #13
swamp rat
swamp rat's Avatar
Well that bites. Just like the roofing company i hired to do my house. I picjed a comoany that dad been in business the longest.. they promptly went out of business but the other two i got bids on are thriving..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
