03-16-2015, 10:23 PM | #1 |
Throttle linkage
I have a 69 gmc c1500 and the factory throttle linkage does not hook up to the edelbrock carb I put on. Has anybody had the same issue and found a good linkage to replace a factory one?
03-17-2015, 07:58 PM | #2 |
Re: Throttle linkage
I have a holley not an edelbrock so the return spring setup is different but you can use either the Edelbrock linkage or a Mr Gasket one like I have if you get the correct bracket for the throttle return that fits your carb. The Mr Gasket kit includes a rod threaded on both ends, the ball joint and a adapter to attach the ball to the carb and the clevis, clevis pin and cotter pin will attach it to the stock pedal. A separate bracket is needed for the throttle return spring.
03-17-2015, 10:54 PM | #3 |
Thanks for the pics and info I will look into it
03-17-2015, 11:46 PM | #4 |
Here are a couple links that may give you some ideas.
http://www.fordmuscle.com/archives/2...rottleLinkage/ http://www.summitracing.com/search/p...ttle%20Linkage |
