Old 03-17-2015, 02:07 AM   #1
Donaldo
AD hood alignment hinge ?
Today I removed the hinges and bracket, I found some putty under the alignment bracket where it bolts through the cowl. Is this correct 'GM Putty' for sealing or something someone has added ?
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 03-17-2015, 03:46 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: AD hood alignment hinge ?
It seals the cowl holes where the hood hinge bolts go through. It needs to be put back there so you don't get a leak into the cab
dwcsr is offline   Reply With Quote
Old 03-17-2015, 11:16 AM   #3
Donaldo
Thanks Dave, that's kinda what I figured. Just wanted to be sure. I have a block of GM putty just for such things :)
Thanks, Don
