03-17-2015, 12:55 PM | #1 |
Camshaft swap on SB 350/290hp
Hey guys, looking for some advice. I have a Chevy Performance SB 350/290hp in my C10. She runs fine, but I know she is capable of more, especially when it comes to low end torque and acceleration. I have seen many posts on this site about the stock camshaft being a bad match for this engine. I am thinking about swapping it out. Don't need a street demon, just something with a little more low end torque and acceleration. Don't want to burn through tires, but a little bark would be nice. Any suggestions on the right cam would be appreciated, thanks.
1967 Chevy C10 Stepside SWB - 350/700r4 |
03-17-2015, 01:08 PM | #2 |
Re: Camshaft swap on SB 350/290hp
The Melling MTC-1 RV/towing cam was a common upgrade for many years. Thus they can be had pretty cheap.
03-17-2015, 01:48 PM | #3 |
One of the First
Go over to engine/drivetrain section. Always good discussions on this subject.
http://67-72chevytrucks.com/vboard/f...splay.php?f=24
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
03-17-2015, 01:52 PM | #4 |
12-300-4 allows all stock components but has enough low down grunt.
03-17-2015, 05:59 PM | #5 |
Location: Formerly MD and San Diego, now loving life in Arizona
Check out the Lunati cams. Good options there.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
03-17-2015, 06:52 PM | #6 |
what rear gears?
how is your timing set up?
JJ 71 SWB 360 Th400 4.56 |
03-17-2015, 09:12 PM | #7 |
Rear gears are 3.73 with a 700r4 transmission (which will being rebuilt at the same time the cam is swapped out). The base timing is 16 ( no detonation) with total timing at 36 (vacuum advance is hooked up.
