03-17-2015, 04:53 PM | #1 |
Pressure In Fuel Tank When Removing Gas Cap
I sure could use some advice on this one...
'87 GMC square, 305/700R converted to carb. Running a Holley Red with a filter inline before the pump and a regulator at the carb. Because of the low fuel pressure of the pump, it's a returnless system. I just got it back from the body shop today - the paint looks great, for what it's worth. While it was in the body shop, and the bed was off, I had them install a between-the-rails 19 gallon fuel tank, with the fill now in the bed. It starts and runs great, but I only drove it about 1 mile to the shop of a friend of mine who'll tuck it inside for me. On the way there, I stopped for gas because the body shop mechanic forgot to install the new fuel gauge. When I unscrewed the gas cap (threaded, with an O-ring seal), I smelled raw gas, and when I got it almost completely out, a real blast of air came out; no fuel, just a hell of a lot of air. It's almost like the tank is pressurized. Any thoughts on where I could start troubleshooting this, or is it nothing to be concerned about? Jerry |
03-17-2015, 05:07 PM | #2 |
Re: Pressure In Fuel Tank When Removing Gas Cap
I'd get a new vented gas cap. If that isn't possible (because it sounds like a custom cap) then the shop should install a vent line.
Matt 43 |
03-17-2015, 05:53 PM | #3 |
Head back to the shop and have them finish (you did pay for it correct?) Sounds like they forgot to vent the tank somehow.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
03-17-2015, 06:14 PM | #4 | |
The tank is a POL piece, and I do know there's a bung in a corner that could be a vent or return line. Given the horrible access to the tank once it's in, I'm finding chopper (motorcycle) tanks seem to run the diameter threaded and vented cap, so I may give him the option to switch to one of those. I have a bed cover on it already, so the visual wouldn't phase me. Jerry |
03-17-2015, 06:20 PM | #5 | |
I know the shop will check the vent line, but I like to be able to talk to them somewhat intelligently... Jerry |
03-17-2015, 06:30 PM | #6 |
temperature change inside the tank could cause pressure to build
84' C-10 Custom Deluxe 97' & 98' C-1500 Silverados |
03-17-2015, 06:51 PM | #7 | |
When I was a teenager, I pumped one heck of a lot of gas, and remember this would sometimes happen with the old style gas tanks and caps, but being young and dumb, never bothered to ask "why"... Jerry |
03-17-2015, 08:10 PM | #8 |
The temp change could be the result of the sun. It doesn't take long. Lost a couple gallons with a venting issue of my own. Disconnect the fuel line, and just the sunlight was enough to push fuel out the open line. (yes, dumb of me. I was just going to the parts store...)
03-18-2015, 04:14 PM | #9 |
I had the same issue with mine after changing to TPI..I drilled 2 small holes in my gas cap so it can vent. No more issues.
03-18-2015, 06:53 PM | #10 | |
I spent a ton of time trying to research the issue, and noticed a lot of the aftermarket vented caps had a pretty simple hole in them. I've never been one to fill up my fuel tank all the way into the neck, so I may go with this as a fix... Jerry |
03-18-2015, 07:49 PM | #11 |
If the weather is nice, they are always going to push air. When you filled it, the gasoline coming out of the ground was at 55*. Warm it up, it will expand.
A couple of 1/16" holes is plenty. I fill mine to the top, and the only time I ever have any leakage is if I stop with very full tanks pointed uphill on my 13* driveway slope.
Rich Weyand 1978 K10 RCSB DD. |
03-18-2015, 08:14 PM | #12 | |
Jerry |
