03-17-2015, 08:45 PM | #1 |
Can someone identify this for me?
When I swapped out my motor I remember this being hooked up to a wire and I just seen that it is disconnected. I must have forgot to hook it up. And I had it at the shop to tune/time everything and they didn't hook it up either. Or either it came disconnected somehow. Anyways just trying to figure out what it is and if it's important to have hooked up. In the picture it goes into the top of the block right behind the intake manifold and next to the distributor. It looks yellow and dirty with one connection point on top. Thanks for your help.
03-17-2015, 08:55 PM | #2 |
Re: Can someone identify this for me?
Very important!!
Oil pressure sending unit!! |
03-17-2015, 08:55 PM | #3 |
Oil pressure sending unit .
1985 Chevrolet Custom Deluxe 4x2 , 305 v8 , 700R4 transmission |
03-17-2015, 09:04 PM | #4 |
Ok thanks guys. I knew I knew what it was just couldn't rememeber and tried looking it up on the Internet just couldn't rememeber exactly what it was to search for. And this just sends the pressure amount to the oil pressure gauge so I know what it is correct? I must have knocked the wire off the other day while working around it taking the kickdown cable off.
03-18-2015, 11:36 PM | #5 |
you need to replace the vacuum plug also I see it is split it will suck air like it is
4x4k30 if trouble was money i would have plenty |
03-19-2015, 02:33 PM | #6 | |
it is a grounded system that sends an ohm value "to" the guage and tells it what position to set the needle. in very simplified terms |
03-19-2015, 05:12 PM | #7 |
The wire that hooks to it should be tan.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
