Old 03-18-2015, 04:27 PM   #1
morethanstock66
morethanstock66's Avatar
Fuel Sending Unit Fitting Question..
So I swapped the in cab tank for a new one and a new sending unit. I took out the old one, put in the new gear. No leaks, runs great and then I turn it off and the sending unit-fuel line connection is just weeping a bit. I decide to snug it up, 1/4 turn, and it snaps. Now the tank has gas in it and the brass snapped in half.
My question is, Would it be worth it to remove old brass fitting, off of the old tank and putting it on the new sending unit in the new tank? Problem is that the sending unit line is flared on the inside and soldered to the brass on the outside. Otherwise it is getting a new sending unit and that is $50... Thoughts?
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 03-18-2015, 07:00 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Fuel Sending Unit Fitting Question..
Will the brass fitting come off the chrome line? If it does, can you use a compression fitting on that line? It may take an extra fitting to complete that.
Look at the picture with the green check mark.
http://www.thomson-caravans.co.uk/ad...ionfitting.htm
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-18-2015, 07:07 PM   #3
cv65
cv65's Avatar
Attachment 1379508
#1 cut off brass fitting,use fuel hose and 2 clamps,probably not the safe fix!
#2 bite the bullet and get the 50 dollar sender. sleep at night enjoy your truck and get ready for the next------ problem,you know its coming !! #3 or use compression coupling as suggested above I didnt think of that
cv65 is offline   Reply With Quote
Old 03-18-2015, 07:30 PM   #4
cv65
cv65's Avatar
not $50.00 but close
http://www.ebay.com/itm/1960-1966-Ch...p2056016.l4276
Old 03-18-2015, 07:55 PM   #5
61_FL_Apache
Who Me?
Originally Posted by cv65 View Post
Im guessing that brass fitting is fixed to the line and cant be removed.
Steve
2001 Blazer 4D 2WD
Old 03-18-2015, 09:58 PM   #6
pimpston65
pimpston65's Avatar
see if you can find an NOS sending unit...
pimpston65 is offline   Reply With Quote
Old 03-19-2015, 05:50 AM   #7
luvbowties
luvbowties's Avatar
Smile Re: Fuel Sending Unit Fitting Question..
Should u decide to use 'rubber hose and clamps', buy fuel-injection hose for the flex. Next time, hold both nuts up close to each other when tightening.
Sam
luvbowties is offline   Reply With Quote
Old 03-19-2015, 05:53 AM   #8
luvbowties
luvbowties's Avatar
Attachment 1379508
Have u talked to seller about replacing unit/?...maybe all u have to pay would be shipping. Keep in mind, it must've been made from less than quality product in the 1st place. Lastly, before investing too much, and if using stock gauge, ensure the sender is a 0-30 ohm unit!
Sam
Old 03-19-2015, 09:43 AM   #9
63burban
Chevy addict
Compression fitting
63burban is offline   Reply With Quote
Old 03-19-2015, 09:44 AM   #10
morethanstock66
It will if I cut it off, which is why I was thinking of just replacing it with the old brass fitting off of my old sending unit, they are flared and soldered on. I didn't think about a compression fitting..
Not easily, no.
I have been looking, nothing yet. Nothing has the strength of NOS.
Sam
I was thinking the same thing, thin-walled brass. It is a stock gauge, 30ohm.
