![]() Join Date: Jul 2010
Diy spid
Hi folks,
Been spending some time at the PC lately in an effort to come up with my own SPID for my suburban. I was unhappy with what was available and thought I could do it myself. I did a lot of research on the font and as many have discovered, it is no where to be found. So in the modern computer era, I figured there has to be something that is close that would only be discernable to the purist of the hobby. I do believe I was successful and was able to find a font called "Artisan 12" from the dafont.com website. I uploaded it to my PC and at first tried to make a bit of a template using word, but was very quickly dissatisfied with the results and the effort with the alignment. Switching over to Excel proved much easier, all told, I would say I have about 1.5 hours in the project total. I ordered a couple of blank SPID's from LMC for about 5 bux each. Next just printed the 'beta' SPID on regular paper and held up to the blank. Made notes where I needed to tweek the alignment and sizing and reprinted. I probably printed about 15 'betas' until I had what I thought was an acceptable template. After each print, I would hold the blank SPID behind the printed page and using a flashlight aligned the columns. A glass coffee table with a light underneath would have been the optimum method I believe. Once I was sold that I was in the ballpark, I used some of the wives double stick 'scrapbook' tape and taped the blank SPID onto a final 'beta' piece of printed paper aligning it as before using the backlight method. Then printed it again with my printer. Being that the ink is not what I would call UV and or waterproof, I plan on covering up the SPID with a clear piece of vinyl. In looking at numerous SPID examples, I did find some consistent areas to base my template on, in particular the wheel base dimension was always aligned under the second "I" in "IDENTIFICATION" directly above the box. The VIN number 3rd digit was typically under the "S" of SERVICE. I also noted that with very few exceptions the interior color code was on the bottom left column and the exterior paint code on the bottom right. The basic 3 digit RPO's are basically alphabetical, with no real rhyme or reason of left or right column. Below is a photo of by 'before' and my 'after.' All told, I have about 6 bucks plus time into the project. If interested in my excel file, send me a PM and I will email you the file and you can determine if it may work for you. I also included another project that I just completed for the Jack Stowage decal. This is not reproduced by any vendors that I am aware of. Let me know what you think.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5
Re: Diy spid
I certainly no expert but the SPID looks good, too good
![]() I meant to ask how the jack storage sticker was coming
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
The Older Generation
Re: Diy spid
Your SPID & jack decal look great.... I did the '67-'68 pickup one because it is not reproduced so I can appreciate the amount of time you have invested in them.... http://67-72chevytrucks.com/vboard/s...d.php?t=520919 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-19-2015 at 12:03 AM. |
Re: Diy spid
Just wondering what could be done if I don't have the original to go by???
Re: Diy spid
You can create your own, make a list of the factory items that you can determine that you have. Many of us make our 'new' SPID labels with our additional 'factory' items we add, like Tach, Vacuum, Posi, A/C, etc. Lots of resources for RPO codes, but one of the best places is this site SPID label threads. You may get lucky and have a build sheet still lurking under your seat, it will be between the foam and spring. Good Luck.
![]() Join Date: Oct 2004
Re: Diy spid
Looks real nice!
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners ![]() 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
![]() Join Date: Mar 2013
Re: Diy spid
This is the best reproduction SPID I've seen. It's almost disappointing to know that I'll have to start finding new ways to determine whether options originally came on a truck, or if it's a true shortbox, etc. Very nice work.
Jeff |
Re: Diy spid
Can't find the blank SPID stickers at LMC. Can you share the link? Many thanks and great work!
========================================== Miles 1972 GMC Suburban K15 - Custom Deluxe |
Re: Diy spid
Here you go:
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=158 P. 158 in their online catalog, part number is 38-0196.
Re: Diy spid
Classic Parts has them also. http://www.classicparts.com/1967-72-.../#.VQ-UvqrVrTo They call it an "Option List Decal" LockDoc
Re: Diy spid
Very cool I would like to do a custom SPID for my truck.
Re: Diy spid
#13 |
Re: Diy spid
That looks fantastic. I am sure it is worth the money you spent!
JB
#14 |
Re: Diy spid
Thanks! Coming from you, it is a real complement!
#15 |
Re: Diy spid
It's been going on for over 25 years that I know of. I bought blank SPIDs from Cheyenne Superman/Gary Terry in the late-80s.
#16 |
Re: Diy spid
Nice work!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
#17 |
![]() Join Date: Jun 2002
Re: Diy spid
JB, if you send the excel worksheet does the font migrate or do I need to download the font from the site you mentioned?
Great work on this, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#18 |
Re: Diy spid
RG, should be in you inbox.
#19 |
Re: Diy spid
Thanks, I appreciate it.
Rg
#20 |
Re: Diy spid
Sent you a pm. I'd love to get a copy of your spid sheet. Thanks.
1967 Chevrolet 1/2 ton 4x4 1972 GMC 1/2 ton 4x4 2005 Chevrolet 1500 4x4 Suburban (302K) 2004 GMC Envoy 4x4 (wife's) 2011 Chevrolet 1500 4x4 Suburban |
| Bookmarks |
