Old 03-18-2015, 09:33 PM   #1
1968aj
does this look right???
I bought this truck a couple of days ago. took a chance and drove it 200 miles back home. made it with no problems. it has what looks like a one barrel carb. has a 350 v8 . did they come like tis from factory? I never saw this combination. anyway it idles too high when cold . will not idle at all when warm. maybe the choke thermostat?? old farm truck with 4 in floor
1968aj is offline   Reply With Quote
Old 03-18-2015, 10:03 PM   #2
undertaker72
undertaker72's Avatar
Re: does this look right???
that's Rochester 2 barrel carb and they did come with them , the choke could be out of adjustment or the themostatic spring shot , just a safety sugjestion , I would loose that neoprene fuel line , as that's a invitation to a fire , expecialy as close to thet exahaust manifold , see if you can find a steel line or go to napa and buy a new one and bend it up to fit , they have them witht the double flare fittings at both ends , good looking truck even has the optional side tool box , and usually they are roached out nice truck
undertaker72 is offline   Reply With Quote
Old 03-18-2015, 10:07 PM   #3
1968aj
yes that fuel line has to go. its even zip tied to the heater hose.
Old 03-18-2015, 11:12 PM   #4
Heck n...yep, that looks like a 2bbl 350 to me. Looks like you have a '73 tool & stowage compartment door. I've had one like that, latched just fine,too.
Old 03-18-2015, 11:13 PM   #5
71K20chevy
71K20chevy's Avatar
Sounds like vapor lock looking for a place to happen! That could be part of it not idling when hot.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-18-2015, 11:23 PM   #6
James Pierce
Active Member
Nothing to do with your fuel problem but a two barrel and stick shift just might
be a 307 CID. Check the stamp number on the block. Just FYI.
cascadeheavychevy
67 C10 327 4speed
69 C20 350 4WD 4speed
69 C20 350 4 soeed
69 C20 CST 350 Auto
70 C10 307 4speed
71 GMC Supr 350 Auto
70 C10 350 Auto
67 CST 327 Auto
James Pierce is offline   Reply With Quote
Old 03-19-2015, 12:16 AM   #7
1968aj
spid says 350 but also says turbo hydromatic. could have been changed. has high hump floor. will get picture of spid tomorrow.
Old 03-19-2015, 12:42 AM   #8
Engine could be swapped or just the manifold. Do I see blue paint peeking through on the manifold? Get us a picture of the harmonic balancer and/or read the engine code
Old 03-19-2015, 06:52 AM   #9
hamjet
hamjet's Avatar
Looks like a new choke pull off, new bolt holding carb on, someone was trying to correct the problem before you got it. (notice how gas was leaking on manifold, then wiped off).. Choke pull off rod needs adjustment for the cold high idle, could be a vacuum leak, idle adjustment for low idle. nice looking truck by the way...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 03-21-2015, 01:50 AM   #10
MikeyMan
Nice catch on the blue paint!
Sure sign of a swap or mix 'n match.
MikeyMan is offline   Reply With Quote
Old 03-23-2015, 10:53 PM   #11
1968aj
well, I messed with the carb with no luck. started to just buy a new one. $250 for a rebuilt??? thinking now to just change to a 4 barrel. any suggestions on which carb and to intake to buy? not looking for high dollar just easy swap and dependable.
Old 03-24-2015, 12:49 AM   #12
Raider Rudy
Raider Rudy's Avatar
You can try a kit & a new float before you do a change over to a 4 barrel. With carb cleaner its about a $30 job. I run a 2g rochestor on the 327 in my 68 & it has good power. Just another option, have fun!
1969 Chevy Long Fleet Custom C/10 (2nd owner)
1971 Chevy Short Fleet Custom C/10 (2nd owner)
2001 Chevy Silverado Ext Cab
Raider Rudy is offline   Reply With Quote
Old 03-24-2015, 03:03 AM   #13
MikeyMan
Don't throw away big money on a new 4bbl & intake just yet.
Invest in a rebuild kit, or take it to someone who knows these carbs if you're not comfortable doing it yourself. Address that fuel line. Check for vacuum leaks. Looks like you've got conventional ignition, probably could use a tune-up too.
Nothing wrong with a 2bbl on a 350.
Saved my 2bbl & intake from my old '74 Malibu Classic with a 350. Put it on a 350 crate motor, added HEI, and dropped it in an old C/10 beater and that thing flat-out flew! Decent gas mileage too.
You should check the casting numbers on the block and confirm what size engine you have. Could be a 350, 307, or even a 327. I once looked to purchase a '70 C/10 that had a later year (Blue paint) 305 coupled with a 3-speed manual. So, you could have just about any size V-8 in there.
Post a couple more pics of the carb w/o air cleaner, as well as the harmonic balancer if you can.
Old 03-25-2015, 12:22 AM   #14
1968aj
want to thank everyone for trying to help me out. found a guy who rebuilds and repairs carbs. on my why to see him when somebody came along that wanted this truck more than me. it now has a new owner.now I can get back to work on my 69 swb.
