Need help vin # on frame
Bought a 1948 3100 with a different frame under it, need to know where vin # is on the frame to get it titled.
Re: Need help vin # on frame
There are no numbers on a 1948 frame.
Door jam drivers is the serial number of your truck that (besides a stock engine stamp #)
are the only numbers on your truck............unless it has been re-registered by a State DOT WHAT does the title have on it?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 Last edited by solidaxel; 03-18-2015 at 10:34 PM. Reason: add |
Ok thanks
![]() Join Date: Apr 2010
Frame stamping started in 58 or so I'm told.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
No title, check the glove box and every hiding place inside the cab for an old registration slip that will have the vin used with the state it was last registered in.
They should use the door post tag number if it has the weight tag on it with the number stamped in it. It's actually the "serial" number rather than a Vin number. There is pretty good info here http://www.sanjosechevys.org/Tech/te...chevtrucks.htm that will help you read that serial number and decode it.
My '57 has a frame stamp.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
Was it from the factory or a State stamp, is it the same number as the door serial #
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
I am in the same situation, with mine in California,
the title i got with the truck had the original engine number as the "vin" number, but it did not have the original engine in it. California does not recognize engine changes, so there for all i have to do is get a new vin number issued. sounds easy, but we are talking California. NOT!!!!! |
