Old 03-19-2015, 12:31 AM   #1
71_jimmy
Windshield sag - door alignment difficulty
Hey all. Had my 71 jimmy for about a year and a half. Been dealing with rust. So far I have replaced upper windshield, rocker panels and a few other small rust areas. Went to try and align the doors today and noted that the upper door seemed to be hitting the windshield. Looks like the top of the windshield has sagged down a little bit. Any tips on getting the doors to align on these trucks or how to correct the sag?
71_jimmy is offline   Reply With Quote
Old 03-19-2015, 06:31 AM   #2
wannabefastcrf
Re: Windshield sag - door alignment difficulty
I'm at the same spot. I heard the vent windows pull the door frame down just a bit. Are yours in or out right now.
wannabefastcrf is offline   Reply With Quote
Old 03-19-2015, 09:39 AM   #3
71_jimmy
Yes they are out. Perhaps I'll try popping them in real quick and giving it another shot
Old 03-19-2015, 10:52 AM   #4
CTENTA1
Registered 1971 K5
I believe your rocker boxes play a big role in this, are they on and if so in what condition?
CTENTA1 is offline   Reply With Quote
Old 03-19-2015, 03:47 PM   #5
71_jimmy
They are in and from the looks they look ok. If it were the rocker boxes how would I go about fixing them? Are they the boxes themselves or the structures underneath them
Old 03-19-2015, 06:38 PM   #6
Blazerowner
Blazerowner's Avatar
Try putting a jack under the body near the rocker boxes where the frame mounts and jack it up a little (use a block). It's a common issue when you do a bunch of repair. If needed align the doors using this method then try to reinstall the boxes. There may be some play when they are removed. Are all the body mount bushings good? That can cause issues as well.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 03-20-2015, 12:28 AM   #7
71jimmy
71jimmy's Avatar
Have you replaced your body mounts? Did you have your hardtop on while doing the rust repair?
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
