03-19-2015, 09:14 AM | #1 |
47-54 Trailing Arm Rear Suspension
We have made a big change in rear suspension offerings for the 47-54 1/2T shortbed (wide chassis). We now have in production a trailing arm rear suspension package for these trucks. The wide tapered frame is a natural fit for a trailing arm suspension. These are available with Viking double adjustable coil-overs ($1175), with air ride using an 8000 series Firestone rolling sleeve bag and Nitro shocks ($1175), or as the trailing arm kit only - no shocks or bags, ($745). All kits include a new front crossmember, front trailing arm mounts, trailing arms with adjustable monster ball ends, axle saddles, U-bolts, Panhard rod and mounts and complete hardware pack. Coil-over kits add lower shock mounts and spacers, billit viking double adjustable shocks, springs, upper shock crossmember and hardware. Air bag kits add Firestone 8000 bags, upper bag mounts, upper and lower shock mounts, shocks and hardware.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
03-19-2015, 09:45 AM | #2 |
Re: 47-54 Trailing Arm Rear Suspension
Do you have a picture showing one installed? Im interested.
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber. If it aint broke I still try to fix it! |
03-19-2015, 03:44 PM | #3 |
Nice looking set-up...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-19-2015, 04:10 PM | #4 |
coming soon, with full instructions.
03-19-2015, 05:48 PM | #5 |
That should make a of guys happy. I was pondering the merits of pulling the trailing arm setup out from under a trailer I have that uses a 70 C10 chassis and putting it under my 48 on the way home today.
04-13-2015, 10:50 AM | #6 |
Good morning. I have a 1948 Chevy 3100. Is that the narrow or wide frame?
04-13-2015, 01:42 PM | #7 | |
3600 and 3800 are narrow. |
04-13-2015, 05:53 PM | #8 |
Hollister Road Co.
I like this kit , having made several for 47-53 $1175 seems a decent price when you consider the time it takes to convert a 72 setup to fit.
What's the wall thickness on the trailing arms? Do I see a booster mount on the cross member? That solves some issues on 3100's |
04-14-2015, 08:55 AM | #9 |
Yes, considering that the RideTech coil-overs list for $575.00, we think it a very good value. The trailing arms are .120 wall. Yes, there is a booster mount on the crossmember. This can be linked to the OE pedal with a pushrod, and mounts the booster/master farther back, out of the way of transmission crossmembers, headers, and all of the heat. It is a standard square pattern, so most aftermarket and OE boosters will fit. We commonly use the 8" dual diaphram Delco units.
04-14-2015, 11:26 AM | #10 |
nice work rob
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-14-2015, 11:29 AM | #11 |
That keeps looking better all the time. The built in booster mount solves one more problem that a lot of us face.
01-26-2019, 08:56 PM | #12 |
Here are pictures of the No Limit Trailing Arm kit on my 49' 3100. The kit went in smooth, however the RideTech coilovers were a few inches too high. I swapped them out for some smaller QA1 units.
01-28-2019, 09:52 AM | #13 |
Kaliforniaman, please PM. Thanks.
01-28-2019, 03:09 PM | #14 |
I couldn't see what was going on very well with the dark photos so I lightened them up a bit.
Rob, I am going under the assumption that that will work with the GMC half ton long wheelbase frame that is stretched in the middle but wide at the rear like a short bed? I may have to sell off more junk now that I see those photos
02-06-2019, 05:47 PM | #15 |
I like this! Can the cross member be narrowed to work on 3600's?
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
02-07-2019, 09:40 AM | #16 |
This rear suspension is designed for the "Tapered" rail chassis. Narrow in front (28" or so) and wider in the back (46" +/-). This rail lay out fits very well with a trailing arm suspension. 3/4 tons that stay parallel at 34" out back would be better off using our FatBar 4 bar suspension.
11-30-2019, 01:23 AM | #17 |
Is this trailing arm setup a better suspension for autox as compared to a four bar design?
On the fence whether to modify my original frame or start over with an aftermarket chassis. |
11-30-2019, 03:18 PM | #18 |
hey rob - am I correct in that this crossmember does not include a rear trans mount? can you provide dimensions as to where it mounts to the frame? Also, how do you think this set up would work with a dropped front axle on stock springs? Thanks.
