Old 03-19-2015, 07:33 PM   #1
SayBye
SayBye's Avatar
What's missing?
What am I missing from my gas pedal to make it functional?
SayBye is offline   Reply With Quote
Old 03-19-2015, 07:33 PM   #2
SayBye
SayBye's Avatar
Re: What's missing?
Pedal
Old 03-19-2015, 07:55 PM   #3
PGSigns
PGSigns's Avatar
Re: What's missing?
Two ball studs that stick out the floor. Do some cleaning and scraping and you should find the holes or the remains of the old studs.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-19-2015, 07:58 PM   #4
SayBye
SayBye's Avatar
Re: What's missing?
I'm not sure but it looks like there's a square sheet metal patch where I'm guessing the studs should be.
Maybe someone cut them outta the floor at some point?
Old 03-19-2015, 08:37 PM   #5
bhc41051
bhc41051's Avatar
Re: What's missing?
http://www.classicparts.com/1964-70-...tinfo/39-375/#
Your typical previous owner shenanigans
bhc41051 is offline   Reply With Quote
Old 03-19-2015, 08:41 PM   #6
SayBye
SayBye's Avatar
Re: What's missing?
Thanks for the link, anyone have a pic of them in the floor board? Does the top of the pedal just rest on the medal piece?
Old 03-19-2015, 08:57 PM   #7
bj383ss
bj383ss's Avatar
Re: What's missing?
Yes the pedal just rest on the arm.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 03-19-2015, 09:21 PM   #8
Ratpin
Ratpin's Avatar
Re: What's missing?
Mine has never had a pedal... drives fine.
"It ain't as easy as Chip Foose makes it look"
Ratpin is offline   Reply With Quote
Old 03-19-2015, 10:18 PM   #9
Bears63
...just another truck junkie..
Bears63's Avatar
Re: What's missing?
I can't help but chuckle a bit. I used to have a '68 that was missing the pedal and I can say it works fine but will wear a hole in the sole of your boot over time. I looked for some pics of the studs installed in my '63 but came up blank.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 03-19-2015, 10:21 PM   #10
dtkarst
Re: What's missing?
I drilled holes and bolted mine in with 1/4" bolts
dtkarst is offline   Reply With Quote
Old 03-19-2015, 10:48 PM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
Re: What's missing?
You might find it easier to use a 60-63 pedal, since the stud mounts are missing. Just position the pedal on the floor where it fits best then drill and bolt in place.
http://www.classicparts.com/1960-63-...tinfo/39-314/#
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
