Old 08-27-2003, 07:53 PM   #1
Eddie H.
Eddie H.'s Avatar
I want one of these engines for my truck
Check this out: http://www.dynacam.com/index.htm
I wonder how it would work in a truck? It weighs 300 pounds,
and puts out 650 pound feet of torque at around 2000 rpm.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 08-27-2003, 08:37 PM   #2
Class of 69
Class of 69's Avatar
The took a A6 compressor and made a motor out of it!!
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 08-27-2003, 09:13 PM   #3
Eddie H.
Eddie H.'s Avatar
That's what I thought the first time I saw it too. It looks just like the old A6 compressor. I wonder what that puppy would sound like with headers and turbo mufflers? It's supposed to be like a 12 cylinder recip engine.
Old 08-27-2003, 09:50 PM   #4
Class of 69
Gotta be small cylinders for only 200 horse out of twelve piston's. It might sound good, and very unique.
Old 08-27-2003, 10:59 PM   #5
tom hand
CCRider
tom hand's Avatar
It is 375 ci. The reason the horsepower "appears" to be so low is it is a low rpm engine. Dyno's only measure torque...horsepower is a mathematical equation....RPM x Torque / 5252 = horsepower. If this thing puts out what they say it does, it would put a big block to shame, BUT it would suck with a standard 3 or 4 speed transmission. You would need a bunch of gears to take advantage of its small powerband.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 08-28-2003, 12:01 AM   #6
bpmcgee
bpmcgee's Avatar
It's an interesting design. If you go to the site, it has 12 cylinders opposing each other in banks of 6, but only 6 pistons.
Each piston is double-ended, and the expansion of combustion gasses from one cylinder pushes the piston down into it's opposing cylinder. Kind of like a steam engine getting power from both directions of the stroke.
The powerband, as they noted, though, is pretty small. Seems to redline at 2k. Maybe REALLY tall rear gears and a 6-speed?
Brian
bpmcgee is offline   Reply With Quote
