Old 03-20-2015, 10:13 AM   #1
Matthewjb
Tire Dry Rot
My frame is almost 100% complete (suspension, brakes, etc.), but I dont have tires and rims yet. My question is if I buy rims and tires to get frame rolling, but I probably wont be finished with the restoration for a couple of years. Will the tires dry rot just sitting in my garage.
Matthewjb is offline   Reply With Quote
Old 03-20-2015, 10:17 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Tire Dry Rot
Unless it will be sitting for 5 or 10 years... I don't know about "dry rot" but I would put the frame on jackstands to alleviate any flat spots in the tires.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-20-2015, 10:26 AM   #3
Matthewjb
Re: Tire Dry Rot
Awesome, I will definitely try that. Thanks!
Old 03-20-2015, 10:28 AM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Tire Dry Rot
I would just put some cheap rollers on it until you are closer to driving it.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-20-2015, 10:43 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Re: Tire Dry Rot
I was reading about that a while back. It said that the newer tires come with a coating on them to prevent deterioration. If you wash the coating off and don't use them they will deteriorate. Movement of the molecules in the compound of the tire when driving keeps them pliable, and that is why newer used tires deteriorate so quickly and develop age cracks when they are not used. Older tires are not as prone to deterioration because they have more actual rubber in the compound, whereas the newer tires have more synthetic material and less actual rubber in them.
I agree with Eric, just put some cheap craigslist tires on it while you are working on it....
LockDoc
Leon
Old 03-20-2015, 11:47 AM   #6
MARKDTN
Re: Tire Dry Rot
agree
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
