Front brakes on a Dually???
How do you get the calipers off?
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
Re: Front brakes on a Dually???
It has 2 flat pins on each end that need to be driven out & then there's one retaining bolt.
Ok thanks
