03-21-2015, 12:27 AM | #1 |
Odds and ends from an auto to manual swap
Swapped to a manual in my 71 K10. I have the shift lever (small amount of surface rust) $10, indicators (wire is cut off the picture) SOLD, brake pedal assembly $20, and shift linkage $10. Everything is in good condition. The linkage pivot that bolts to the frame has very little wear on it. All prices plus shipping. Also looking for a manual column bowl, interested in purchasing or trade.
03-21-2015, 03:25 AM | #2 |
Always on the hunt...
Re: Odds and ends from an auto to manual swap
I will take the pictured shift linkage and the shift lever, I also have a manual column bowl available/already pulled for you. Mel
03-21-2015, 04:24 AM | #3 |
I'll take the shift indicator
03-21-2015, 02:18 PM | #4 |
Here are some pictures of the non-tilt 4 spd. column bowl that I mentioned above, this one also has the matching upper manual trans switch cover all removed from a 72 K/5. I also have just the lower column bowl by it self from a 70 4 spd truck (gold in color) but again it doesn't have the matching upper switch cover. Have a post office run planned for later today, let me know and I can get these headed your way. Mel
03-21-2015, 06:22 PM | #5 |
Check your PMs. Thanks, Russ
03-23-2015, 01:35 AM | #6 |
Hey Russ, made it to the post office tonight and the manual shift bowl & upper switch cover are headed your way. Parts were sent out USPS priority Sun. 3/22, your projected delivery date listed on the postal receipt is Wed. 3/25. Thanks again, Mel.
03-23-2015, 03:47 PM | #7 |
Hunter67 - Indicator shipped USPS First Class Mail Confirmation number 9114999944313907840721
ClassicBowties - Linkage shipped Priority Mail Confirmation Number 9114999944313907840738 Thanks, Russ |
