![]() Join Date: Aug 2008
55 second series 3 speed overdrive questions
I am usually on the 67-72 side and have redone a 71 GMC custom swb step and 72 cheyenne swb step. I have a 55 big window that ive owned for 30 yrs (!) that i need to get going again. Back in the eighties my brother installed an overdrive that if i remember correctly came out of a 58/59. Unfortunately the donor truck didnt have any of the wiring or controls. My truck is all original but needs a full restoration. I found a wiring harness from Jim Carter but does anyone have any more info about getting the overdrive working correctly?
Re: 55 second series 3 speed overdrive questions
There are 4 components. Kick down switch, governor, solenoid, and relay. There are wiring diagrams on the web. Use search terms like 55 chevy Borg Warner overdrive. A place called 5th avenue parts garage carries parts an has some know how as well. My 59 has this setup in operating condition.
1959 Fleetside Big Window Long Box Standard Trim soon to be Deluxe 1953 GMC Carryall Suburban Last edited by beanyard; 03-21-2015 at 10:56 AM. |
Here's a factory service manual for the overdrive unit. Should be the same.
http://studebakerclubs.com/NorthGeorgia/Overdrive.pdf These guys are your parts source. http://fifthaveinternetgarage.com/overdrive_parts.php |
