New steering gear and shaft thread don't match
I bought a new steering gear to replace my old one. I removed the old to find that the gear from the box to the shaft are different. How do I fix this? Can the old one be swapped off and replaced?
Truck is a 73 k20
1973 Chevy K20 |
Re: New steering gear and shaft thread don't match
Are you talking about the input shaft or the hose fittings? I believe you can get adapters for both.
are you talking about the threads on the rag joint are you talking about the splines on the rag joint shaft are you talking about the splines on the pinion arm shaft you're talking about the rag joint there are two separate sizes one big one small to align with on the steering colum?
