Transmission cooler questions
Just rebuilding the Turbo 350 in the my 84 C-10. Looking to add a trans cooler and have a few questions.
1. I understand that the coolant goes into the radiator hot at the top and is drawn off cooler at the bottom. Is it the same with the transmission fluid? 2. Do I want to cut the upper line and feed the cooler from that and then back to the radiator? 3. Can I use quality rubber hose or are the pressures great enough that I need to do the whole thing in steel? 4. And finally, is there any advantage to running two coolers in series, or will that cool the fluid too much? I know that transmissions run hotter than the engine. Will too much cooling be as bad or worse than too much heat or am I overthinking this? The truck is used mostly for general light duty. The only heavy loads are generally my 23' travel trailer that I take to the Eastside hunting, firewood or pellets and the occasional load of gravel or topsoil. I just want to give the new transmission the best chance to survive. Thanks for any help Steve
1989 Silverado K2500ECLB- 307K miles with 90 K TBI 350-Not a show truck, a work tool that I can drive! 1998 Dakota EC 250K miles- I guess I'm just a truck guy now! |
![]() Join Date: Apr 2010
Re: Transmission cooler questions
There was a very informative thread on this subject a few months ago. If you can find the thread I believe it would answer all your questions. In my opinion by-pass the radiator cooler and run it straight through your other cooler. I ran mine that way, top to bottom.
Moderator
![]() Join Date: Oct 2008
1 The best way to run a tube and fin external oil cooler is Hot oil in the bottom and cooled oil out the top. This fills the cooler completely before oil flows out the return. That being said I'm not sure how GM ran the radiator tube transmission cooler.
2 Cut the upper line if that's the return line. This should run from the radiator cooler -> through the add-on cooler and continue -> back to the transmission. This is how the Hayden cooler on my 2009 Impala SS and the factory "tow package" cooler on my brothers 1997 W2500 Dodge truck are run. 3 You need re-enforced high temp oil resistant hose. The stuff you're looking for will state that it meets SAE J1019. J1019 hose is rated for 300°F 150°C transmission oil. http://www.gates.com/products/automo...il-cooler-hose Use fuel injection clamps on the cooler hose rather than the worm drive Ideal clamps. The small Ideal clamps have slots that the soft outer hose jacket can extrude through, over time, reducing clamping force and allowing leaks. This is a fuel injection clamp. Note the lack of slots and the fact that the band goes all the way around the hose. ![]() 4 I usually try to setup the flow so the oil hits the radiator cooler first and then the aftermarket unit. It heats the fluid up quickly in the winter and, in the summer, it drops the oil temp low enough that the J1019 hose will last longer. Your goal should be transmission oil temp in the 160°F range. The 4T65E-HD in my Impala ran close to 195°F-210°F just cruising at 70MPH on the highway with spikes to 250... Not good for longevity. Hence the poor reputation for longevity the 7th & 8th Gen Impala transmissions enjoy. The most efficient type of add on cooler is a "Stacked plate" transmission cooler you shouldn't over-cool the system with one of these because the oil will bypass the cooler when it's too cold. You can get thermostatic bypass units but most of them bypass at 185°F and that's too high IMHO. I run a Stacked plate Low Pressure Drop (LPD) cooler after the radiator cooler on the 4T65E in my Impala. http://www.transmissioncoolers.us/ca...cool-thin.html I also replaced the OEM pan with a unit that has a drain plug so I don't wear the tranny fluid when I change it. Painted steel pans with a drain plug are inexpensive. B&M makes a chromed deep extra capacity pan with a drain plug for towing or you can spend more for an aluminum pan. http://www.summitracing.com/search/p...g-included/yes I also use a Magnefine filter with a big magnet in the cooler return hose. ![]()
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 03-22-2015 at 10:15 AM. |
I put a B&M temp gauge on my th 350 and it never gets hot. When I used to mud bogg race it never got hot, and plowing snow for an hour won't get it hot. The only time it ever gets hot is when too much fluid has leaked out of it. Pulling a 23' trailer might make it hot though. If I was only pulling it occasionally, I would see how hot the trans got before worrying about a cooler. However, there is nothing wrong with overkill if you have the time and money.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
That's why the in Radiator coolers work great the tran and eng temps are compatible. Eng helps warm transmission up. With out a temp bypass an external cooler is a crap shoot.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
The radiator transmission coolers are trouble free 99% of the time. I had a 1% moment on my Blazer shortly after I got it. The cooler ruptured and filled the transmission full of water. It happens.... I won't run a water to fluid cooler ever again. The 88-98 trucks have a real nice factory one that could be adapted pretty easy.
I was a heavy equipment mechanic for 35 yrs Almost every piece of equipment I ever seen uses a cooler in the bottom of rad. to cool the trans. And ive seen some fail but every one I ever seen the trans oil ends up in rad. because the psi is considerably higher. We used to put calgon in there flush it out a couple times. oil in the cooling system causes no damage.
#8 | |
Moderator
I do agree the TH350, TH400, & even the TH700R4 & TH200R4 probably don't need external cooling unless you're regularly towing. Put in a cheap temp gauge and if you don't regularly get above 170°F - 180°F or so you don't need to worry about it. You will keep the tranny happier if you keep the temp around 160°F - 175°F. I would add high temp magnets to the pan, one of the Magnefine inline filters, or one of the T800 & T900 series GM Light Truck Allison spin-on filters with a GM filter magnet.
And please let us know if and how your repairs were successful. |
Moderator
These are sustained temps not short spikes.
Would it be a bad idea to just run something like this?
#11 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Great information here. Hatzie thank you for taking the time for writing all that up. One thing thou, I see you guys all live in the northern parts of the country. And you don't see the temps we see down here in Florida, and the traffic jams. Sit on black top bumper to bumper for a couple of hours will over heat trans fluid in one setting. When I worked in downtown Jacksonville Fl. if there was a accident on one of the 3 major bridges it shut everything down. If anyone has ever been to Jax they know about all the bridges, you can't go anywhere without crossing one.
Also from what I have read here lately while looking for a replacement tranny. All the vender's require that you use a add on trans cooler after the radiator cooler, to maintain the warranty. Add the issue of the the radiator cooler rupturing in a way that it fills the transmission with coolant is a rare occurrence. The manufacturer would have changed the design long ago. Most times the cause is over tightening the transmission cooling line fittings. There is a torque spec for those fittings. At the rad. 140 in lbs at the trans 180 in lbs. Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
#13 | |
Moderator
That's a power steering cooler. Not enough capacity to do a transmission.
You folks in the South probably want to get the largest LPD plate cooler you can fit. Oil coolers and power steering coolers become almost a necessity too when you're driving in Miami, Jacksonville, Orlando, Tampa, Atlanta, Dallas, Houston, Vegas, Phoenix, or Tucson traffic and summer heat.
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-03-2015 at 12:41 PM. |
#14 |
Here is my aftermarket transmission cooler a Hayden brand. I did attach the trans cooler to the rad withe the black tie straps. I made up two rods that pass across about 4 inch in front of the radiator and A/C condenser. And the engine oil cooler is a OEM factory option.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan Last edited by 1970pelle; 12-03-2015 at 12:59 PM. Reason: added more info |
#15 |
Moderator
I can talk theory all day long... You don't have winter to worry about so low temp regulation is less of a worry.
How are the summer fluid temps with that setup?
#16 |
At the body shop.
Considered a gauge for my junk, 4k stall and 4000lb truck.
After melting the fat mat sound deadner. I decided I don't want too , run the biggest cooler that fits and bypass the radiator altogether.
" That didnt make it any newer " " Dont antique the equipment " |
