1979 GMC S/B LS Swap-Carb intake
Re: 1979 GMC S/B LS Swap-Carb intake
Nice looking project. Do you have any more info?
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
Sure
I had a ZZ 502 in her; nice for a daily driver when gas isn't 3.80 a gallon. I have done a few vortec swaps in 67-72 Chevy';s and decided to get a bit more economical. 2003 5,3 Vortec Stock Ex. manifolds-I had header problems Edel 7118 intake and performer 600 cfm Stock fuel tank;electric pump/regulator 700R4-Monster Tranny 3.73 rear end Just about it; nothing overly fancy and I have yet to see a carbureted LS in this area. |
Oh, if you are doing an EFI swap; been there on 67-72's. if I can help. just ask...
Very nice, good looking truck!
1983 GMC SWB - 350, TH-400 2002 Camaro SS - 408 9sec street car 2000 Trans Am - H/C/I 2014 Chevy Z71 |
Ok
Very cool, my 76 is almost "road worthy". How is the drivability with the carb set up over the efi set up? I have never driven a carbed ls so I have no point of reference.
![]() Join Date: Jan 2015
Clean swap, was curious myself as to why the carb was used
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
What size tires are you running?
Okay, First of all sorry for the delays; truck has been pitching a Fit.
The Carb LS swap is done; Edelbrock controller is not doing its job very well so back top the Truck Intake. |
Tires on the GMC 1979 were 255/70 15. Found the Rallys on a truck in the salvage yard. 15X8 and the center caps;I think 6 rims and caps for 100 bucks. seemed fair to me.
Also, Carb intake was what I was referencing not running well; fowling plugs. like I said, back to the stock Vortec truck intake:
Fuel system will be a 1987 Fuel Tank and pump set up; pump puts out 135 PSI and the tank is baffled; 200.oo set up from Rock Auto. Fuel out-efi Hose to 10 or 40 Micron inline. 3/8" Not to hose barb input; Braid 6 AN to the inlet on the intake. return line I think is 5/16 and low pre4ssure so I will probably run 5/16 EFI hose to the pump return; not sure if I have enough room for tube to AN crush fittings. I will try and post my results. |
#13 |
Nice clean swap!
