Old 03-22-2015, 11:18 AM   #1
jponfrank
Quick question manual to power brakes
I have a 1975 c10 manual brakes. Disc in front,drum in rear. I bought the kit which includes booster,master cylinder and valve. My question is do I remove the old proportioning valve or can I leave it alone. Thanks Joe
jponfrank is offline   Reply With Quote
Old 03-22-2015, 11:41 AM   #2
Bigstevex4
Bigstevex4's Avatar
Re: Quick question manual to power brakes
A little trick get the part # for it for power and non power brakes. you'll have the answer if its same or different.
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 03-22-2015, 12:11 PM   #3
jponfrank
I think Im missing something here. Can you use 2 valves or need to eliminate the orginal valve.
Old 03-22-2015, 01:01 PM   #4
greg64
greg64's Avatar
I suspect the proportioning valves are the same, but I'm not positive. What bigsteve is getting at is if you look up the part number for the prop valve for power brakes vs non power brakes, you can see if the same part number comes up. Give rockauto.com a try.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-22-2015, 01:01 PM   #5
Titomars
Titomars's Avatar
according to the GM parts manual the prop. valve for 75 is the same for JB1 (manual) and JB3 (11X2 power). It does change numbers with JB5 (11.15X2.75 power) which weren't offered without power.
So assuming you got a kit that converts to JB3 power brakes you are good without changing the prop valve.
But if it were me I would use everything in the kit anyway. I don't short cut my brakes.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 03-22-2015, 01:36 PM   #6
Bigstevex4
Bigstevex4's Avatar
Ya sorry My explain /Typing skills are lacking. Exactly if both setups use the same valve. I would not change it but that's not always the best. If they sent a new one up to you.
90 Jimmy parked
In memorium
Old 03-22-2015, 01:37 PM   #7
jponfrank
Thanks guys for clearing that up
