Old 03-22-2015, 11:27 AM   #1
northern 85
northern 85's Avatar
sway bar bolt holes in a arm???
What year did they start having holes from the factory in the a arms for sway bars??
northern 85 is offline   Reply With Quote
Old 03-22-2015, 11:48 AM   #2
Grandpa54
Grandpa54's Avatar
Re: sway bar bolt holes in a arm???
66?
Grandpa54 is offline   Reply With Quote
Old 03-22-2015, 02:22 PM   #3
pwrbrkpadguy
pwrbrkpadguy's Avatar
My 65 has them. I used a sway bar from a 72 Cheyenne Super. Best upgrade you can do next to an HEI.
pwrbrkpadguy is offline   Reply With Quote
Old 03-22-2015, 02:25 PM   #4
63longfleet
my 63 did not
63longfleet is offline   Reply With Quote
Old 03-22-2015, 03:42 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
66 models were the 1st to have sway bar holes drilled from factory. Least that's the story. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-22-2015, 04:01 PM   #6
cv65
cv65's Avatar
my 65 c10 has them and I know its orginal
cv65 is offline   Reply With Quote
Old 03-22-2015, 04:05 PM   #7
pwrbrkpadguy
Yeah, mine are too. Post #655530 on the Chevy Talk Forum has all the info.
Old 03-22-2015, 05:53 PM   #8
Lugnutz65
Lugnutz65's Avatar
Yep. My 65 has them too. My buddy has a 64 and nada, nope, nothing. He came over to see mine and take measurments.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 03-22-2015, 09:20 PM   #9
racecougar
racecougar's Avatar
Another '65 C10 here with the holes already in place from the factory.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 03-22-2015, 09:23 PM   #10
DPowers
DPowers's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=517255
DPowers is offline   Reply With Quote
Old 03-23-2015, 09:33 AM   #11
1963c-10
1963c-10's Avatar
For those without the holes and looking to add a sway bar, its not a hard process to install one though. I installed a factory sway bar on my 63. Took about two hours start to finish by myself. I purchased the frame mounts from CPP, used grade 8 bolts and had measurements from a member with one installed.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-23-2015, 10:44 AM   #12
TJ's Chevy
TJ's Chevy's Avatar
Looks like I'm buying a 65.
Old 04-21-2015, 03:02 PM   #13
AnlaufJohn
Good grief, those tow hooks are sexy!! Where did you find monster hooks like yours?
Eugene, Oregon
Lucy's Limousine
1966 C-10 LWB
283 w/ 2bbl, OE carb and dist.
4 spd (granny 1st) w/ 3.73 rear end
AnlaufJohn is offline   Reply With Quote
Old 04-21-2015, 04:24 PM   #14
1963c-10
1963c-10's Avatar
They are factory 60-68 gm hooks. They used the same hooks on all their models....from 1/2 ton - 2 ton.
