Where can i find one of these
looking for #5, only place i can find one is LMC. i have had no luck looking on oreillys autozone napa or amazon. i need it for my 82 c10 with a 305.
i have been searching booster line, booster hard line, booster vacuum line... dose it have another name? any help would be appreciated.
Re: Where can i find one of these
Well if you can not find one pre-made, the line is standard 3/8th inch steel line. Get a universal replacement at a parts store and bend to fit then just cut off the 2nd threaded end and surplus for a slip fit to the hose. Another alternative is poke around a wrecking yard. That is not a high demand part out there. So there should be lots of them. Also look on cars with a similar engine package.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
#3 | |
thankyou guys, i may just order it from lmc if i cant find one in the junk yard tomorrow.
At the body shop.
Or a barb fitting and a vacuum hose.
" That didnt make it any newer " " Dont antique the equipment " |
i asked the guy at the part store for something like that because i didn't want to mess with flaring and bending my own line and he looked at me like i was retarded... so a 3/8 NPT barb/nipple is what im after thankyou KQQL IT and enaberif
I guess you went to the wrong parts store. I tend to forget many use those Pepboy's, OReilly's, Autozone's, and others of that caliber. I only use old school full service parts Stores like Napa. Here is a photo of a generic replacement steel line I was refering to. They are sold in common sizes from 3/16 to 1/2 inch and from 12 to 60 inches long.
At the body shop.
anytime, I'm not sure if the check valve is for. Ran mine with and with out one.
Check valve should help hold vacuum to the diaphragm.
At the body shop.
The catalog calls it a filter? I broke mine last time the engine was out. Didn't notice much difference...
The filter is to keep gasoline and oil vapors out of the booster during a backfire. The booster diaphragm does not like those chemicals much.
#13 | |
If you hear neither of these when you pull out the check valve you either have a bad check valve or a bad booster. |
#14 |
PM sent
#15 |
Pretty sure I have one I can give you. PM me.
#16 |
thank you all for the help. i just got back from napa (they were closed yesterday) with a barb and vac line so everything is working well. i kept the filter and check valve but i pulled the valve from the booster to see if it was holding vacuum and was caught a little off guard by how much vacuum it still had... thank you all again
#17 | |
#18 |
At the body shop.
Good deal.
| Bookmarks |
