I'm trying....
![]() Join Date: Oct 2013
Fan shroud/Radiator mount Question
Reinstalling my radiator and fan shroud. Please note part #7 in attached Assembly Manual pic. I am missing this component. I don't see how it works with the shroud clips in place. Is it an either/or situation? Since I have clips, would I not have that piece? Or has this part been lost somewhere along the way? Any guidance (especially with pics) appreciated. 1970 4WD.
Thanks... Brad
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
Re: Fan shroud/Radiator mount Question
I'll check mine tomorrow. BTW, which manual did you use to get that diagram. I'm looking for a body manual but not sure which one to get.
Dan |
Here ya go !! Looks like mine is missing too. I have a feeling it's just a rubber seal to keep debris from getting sucked in by the fan. It looks thick in the drawing, but may have been made from thin rubber. IMO
![]() Join Date: Jan 2000
The only time I have seen part #7 was on a BB 2wd radiator shroud. Mine was on a Longhorn.
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
I'm trying....
Thanks to you both...a picture is worth a thousand words as they say. Feel better about my set up now.
I'll post a pic later tonight of the clip that I pulled off my shroud to see if that helps
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
