Old 03-22-2015, 05:13 PM   #1
PGG
Need advise STAT have 5 guys here to remove top
I have pulled every screw and bolt we can see holding it on and the back lifts up no problem the front seems like its still screwed down. Cant budge it at all.
What am I likely missing? Could it just be glued down?
Thanks PG
PGG is offline   Reply With Quote
Old 03-22-2015, 05:20 PM   #2
PGG
Re: Need advise STAT have 5 guys here to remove top
Found the ones hidden in the visor mount. Sorry for the question. PG
Old 03-22-2015, 05:22 PM   #3
turp mcspray
turp mcspray's Avatar
Front has bolt through sun visor, L brackets in middle of windshield frame, and rubber pieces in upper corners near top of wing windows. Any signs of silicone being gooped on to stop a leak?
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 03-22-2015, 05:35 PM   #4
71swb4x4
71swb4x4's Avatar
Where are the pictures of the Blazer without its top?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
