finished truck today but drop is a little off help
So I drooped truck 4/6
wheels 20/22 Coys 72 BB Cheyenne when you look at front it leans a little to left is it possible that my shock blew out today? Or what would cause this? thanks kerley |
Re: finished truck today but drop is a little off help
I would just double check everything. If it looks good, you could just be another victim of "Chevy Lean". Google "Chevy Lean" and see if that is what you have. I am a victim of Chevy lean on a entire brand new suspension rebuild as well.
I did hotchkis springs and belltech shocks
so I spent no expenses with good parts |
I don't think Chevy Lean is suspension related, but no one really knows. You have to specifically address the lean to fix it. You probably had it before, but didn't notice until you focused on the suspension.
Make sure the front springs are seated in the control arms properly.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
#6 | |
The Older Generation
![]() LockDoc
"""is it possible that my shock blew out today?""" Unless shocks are gas filled or the old type that had coil springs around them they serve no lifting pressure. even gas filled I couldn't immagine they wouldn't have enough pressure to lift that much weight. I think the guys are right, check your perches..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Registered Cruiser
"Chevy lean"is usually a bent frame.
I intend to live forever. So far, so good. |
![]() Join Date: Nov 2004
I'd park it on a flat level surface and bust out a measuring tape before trying to guess whether or not there is an issue.
It also takes a little time and some driving for the springs to settle to their final ride height.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
C10 Collector
Disagree. Usually Chevy lean is from the driver, gas tank, and battery being placed on the drivers side. On a 67-72 though the battery is on passenger side and tank is equally split on both sides, even if relocated to the rear.
PO: How much is it leaning? I would drive it a bit and it will settle some. Do you have a sway bar? Is it adjusted evenly?
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project |
![]() Join Date: Nov 2014
can you park it on level ground and take pics straight on from the front and rear? ...and as 67redneck suggested, bust out the tape measure and measure from the ground to the fender well to make sure it's not just an optical illusion.
That said, let's get technical for a half-second. Damn near all manufacturers of aftermarket springs for 'lowering kits' batch test their springs only, so the likelihood of a slight variation from one spring to the next is pretty good (unfortunately). In racing applications, each and every spring is tested on a dyno for spring rate, uncompressed height, compressed height, 'loaded' height, etc. Nearly no aftermarket mfg's will take corner weight measurements on vehicles and slightly tweak each 'set' to accommodate corner weight differences from right to left on the front and the back. They usually will take a stock spring (1 front and 1 rear) from a vehicle, test it's spring rate (or do rough calculations based on material, height, steel diameter, overall diameter, spring shape (beehive, cylinder, etc) coil spacing, number of coils, progressive or linear, etc) and do a best effort match to accomplish a "x-inch drop". |
here is a pic it leans to passenger side I tried to correct photo with leaning my phone yesterday.
I checked spring seat on the leaning side yesterday and made sure it was locked in the correct position. |
#13 |
back is nice and level
#14 |
Shocks are Belltech gas shocks
Found a few sites that showed different drops for rating Max was 4 inches being a big block I would guess it went down an extra 1/2 |
#15 | |
The side that is down isn't the side that would be out of place it would be the drivers (high) side. LockDoc
#16 |
When I did mine I had a bit of lean as well. I checked everything out to make sure it was seated properly... or at least I thought I did. About a week later I was turning a corner and my front end made a loud pop noise.
I pulled over low and behold my lean was practically gone (Less than a half inch from side to side). So you might just try driving it a little bit to make sure everything is seated properly. Some times those springs need to move just a little more. Hopefully you haven't done your alignment already like I did.... Or you will have to do it again if something does move.
71 swb 350/4sp manual 5/7 static drop |
#17 |
![]() Join Date: May 2014
I think it's cool...just looks like a clapped out ole Chevy! The way we like em :-)
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
#18 |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
When you measure the clearance, it's important to have the truck on level ground, which sometimes isn't so easy to find. Also make sure its a good surface. Concrete or paved. Take it to a level parking lot if you need to. When I installed my skyjacker lift kit on my 71 K10 I took measurements before and after the install. After the install, I rocked the truck up and down several times, on both the front and rear to work the new springs and shocks. Granted now, this is a 4X4. I took measurements again, using the same level location in order to have good comparative results. I measured from ground surface to fender and tire to fender. You can see what I did by looking at post #24: http://67-72chevytrucks.com/vboard/s...d.php?t=620627
The drop looks good. What are the details on your wheels and tires? I know they are 20 & 22" Coys, but what are your tire sizes and backspace for the wheels. Thanks.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#19 |
can't help, but truck looks good!
1972 GMC Sierra LWB (Aquafresh) 1962 Cadillac Convertible 1962 Cadillac Sedan project |
#20 | |
RAT1968 '68 Cab/'71 Parts
When bare of front clip, cab, bed, and without any driveline (except the rear end), my frame was "spec'd" before and after a full frame off suspension treatment. Then, after the build, the height was 1/4" off side-to-side ...maybe a little more. After an alignment and driving it a couple of thousand miles, I don't see the lean any more. Maybe it's not there. Maybe I just don't see it. Unless you have a lean like this, I'd drive it for a while just to see what "settles".
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 03-24-2015 at 12:43 PM. |
#21 | |
Registered Cruiser
#22 |
thanks for the help so far
I have put a ton of time in the truck with my son and call it OCD or 20 years in the Marine Corps I want everything perfect. that pic is funny |
