![]() Join Date: Jan 2015
All harnesses are NOT created equal.
After getting another "NEW" harness in that someone had issues with I wanted to post our commitment to excellence page in here. This will help you guys ask the right questions if you happen to be shopping around for an engine harness.
Please dont take it as me saying we are the only Quality harness manufacturer out there, there are others out there. The page will help you protect yourself from someone who THINKS they know what they are doing. Since it seems there are harness builders popping up everywhere now days. http://www.bp-automotive.com/Commitm...xcellence.html Bill |
![]() Join Date: Mar 2004
Re: All harnesses are NOT created equal.
Just sent you a PM...
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
Hey there... I went to the site and did not see a gen 5 harness available. Do you expect to have them anytime soon? Pricing?
Great looking harnesses Bill. I just shot you a PM to see if you can make something special for my project.
#5 | |
![]() Join Date: Nov 2013
![]() While we're on the subject of harnesses, I had a question come up about the PCM seeing some kind of signal/feedback to indicate that the transfer case was in 4Lo position on a 4WD rig.......is there a way that you address this issue? I have an LS1 and PCM from an '02 F-body car. PCM has already been re-flashed and is supposed to be ready to run the motor. |
![]() Join Date: Sep 2014
I can attest to the excellent quality and customer service I received from BP Automotive. I'm very happy with what I received and their help with my questions.
#7 | ||||
Bill |
email sent
![]() Join Date: Mar 2013
Purchased a full harness and ECU from BP last fall. Can't say enough about it, love it.
that sucks that you're not doing the rewire service anymore
![]() Join Date: Jul 2012
You have a good product BP. Friend used yours recently and we will use your harness on the next two builds we are doing.
I'm just about ready to purchase a harness, but I'm still foggy on a few details.
Fan(s)......... I have a good set of factory fans from '02 F body but I was looking at an Entropy 4 core radiator that has the fans and shroud already attached. THIS ONE They recommend their fan control wiring harness but if I understand correctly, the factory harness will control the fans just the same, as long as they are wired into the harness with the relays and all......? Now, if I add Vintage Air or equivalent, do I need the AC output on my harness to force the fans on when the AC is on.....? Also for the injector connections, what is the difference in the EV1 and EV6 mine has stock injectors I assume. |
#13 | ||
Im sorry! They are just so time consuming, we can actually build a new one faster than rewire a factory harness. You would be surprised how easy it is to close the gap in the price difference once you sold your factory harness. If in good shape most factory harnesses will bring at least $100.
As for the A/C, if you have a LS1 engine and PCM we can make the PCM control that also. You get much better Idle controls, fan controls, and A/C protection when you run through the PCM. To top it all off, its actually simpler to run it like this. Just hook up two wires, and install a GM pressure transducer, and the A/C wiring is done. Just give me a call if you still have any more questions, Id be glad to clear it up for you. Bill 270-805-1777 |
#14 | |
I will be contacting you in the next few days....to finalize the details and place an order..... Last edited by A1971Blazer; 04-02-2015 at 09:31 PM. |
#15 |
![]() Join Date: Oct 2014
You are not reworking harnesses or cheaper making new harness? I have mine and ready for new or remake if you are quoting? 1969 suburban ls set up is 2005 5.3 suburban 4L80e and need relay for dual fans also. pedal will be DBW and I have my ECU
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) ![]() MAI Interior shop |
#16 | |
Bill |
#17 |
Do you do PCM tuning? OK, That's a dumb question, Do you do weird off the wall custom tunes?
I'm installing a '04 Truck 5.3L in a '01 V6 Camaro... I need the Blue/Green Service # 12586242 PCM to control a '99-'02 F-body cluster & 3-relay cooling fans. F-body A/C controls Return trans pressure to stock. (Had it bumped by PCMforless) Tune for 3:42's & 25.6" tire. Vats turned off by PCMforless already. Can you help me? |
#18 |
The rewire option would be nice as I have the full harness for my 07 5.3. 150tunes.com will do the harness and tune the PCM for $400. I've heard all great things about your company, but what will I get with your company vs doing the rewire with the other company? I want good quality and the best bang for my dollar. As the other poster stated I'm going to be running f body fans and a vintage ac system.
#19 |
Hey Bill, can you guys make a harness with a built in throttle body adapter harness? I have a Gen III DBW truck motor (5.3 LM7) and picked up a TBSS intake manifold and throttle body that I plan on using for my build. I know Speartech makes an adapter harness for $60 http://www.speartech.com/product_p/tbadapttruck.htm and Torque Rush makes the X-Link for $235 http://www.torquerush.com/index.html but I’d much rather just buy a harness from you guys with that built in to it from the get go if at all possible…
#20 | ||
Our new harnesses are routed like the Camaro/Firebird harnesses, and are 5ft long with a grommet on the main trunk line. This enables you to mount the PCM inside out of sight, or generally anywhere you want. Once you sell your factory harness, that closes the gap between a rewire and a new harness considerably. A harness from us with the same options they add to a rewire costs $500, and the tune is $100 when purchased with a new harness. Thats $600 for the same options, just $200 difference. Once you sell the factory harness which in good condition brings $100-$150 its a no brainer. Plus our fuseblock is lightyears better. Bill |
#21 | |
Bill |
#22 |
Thanks for the reply, I will give you a call tomorrow.
#23 | |
Out of curiosity, what is the difference between the 01-02 and 03-06 DBW setups that makes them non-compatible? Is one better than the other for some reason? I see the Speartech harness only mentions the 01-02 and X-Link only mentions the 03-06 but I could never find anything anywhere that explained why... |
#24 | |
#25 | |
I have a very good friend that specializes in LSx swaps and he doesn't even think twice about a re-wire service, nor re-wiring himself as it is so time consuming. Easy and hassle free to have everything come to you plug and play with no headaches and focus on the rest of the build. Even better if it is a vendor on the forum who guarantees their work. It was a no brainer to me. I sent my order in for a new harness from Bill @ BP. He has answered all of my stupid/dummy questions and got me straightened out each and every time I have contacted him. Listen to what he says and you won't regret it.
