![]() Join Date: Oct 2014
Front turn signal issue
I have an 86 C10 Silverado. My front yellow marker lights don't work properly with the turn signal. So here's what it does:
With the headlights off: I use the turn signal left- the right side is blinking. I use the turn signal to the right-the left side is blinking. With the headlights on: Both blinkers work properly to the appropriate side Everything else works fine the way they should, it's just the front side markers when the headlights are off. |
| Bookmarks |
