Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-23-2015, 07:51 PM   #1
WEBBY1
WEBBY1's Avatar
cab supports
Is this what you guys are using for cab supports?
http://www.topbananaparts.com/oem-st...support-1.html
mine are completely shot.. these weld? To the inner rocker? And bolt or weld to the frame?
WEBBY1 is offline   Reply With Quote
Old 03-23-2015, 08:02 PM   #2
padresag
Re: cab supports
those are the fronts and you have to fab the one just behind the "B" pillar which would be the rear cab mount on a pick up; bolt and spot weld
ron
padresag is offline   Reply With Quote
Old 03-23-2015, 09:32 PM   #3
WEBBY1
WEBBY1's Avatar
Re: cab supports
Any pics of the rear
Old 03-23-2015, 10:28 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: cab supports
check out my sub build thread in my signature .\/ I have some pics of the mounts ----page 3 post # 51, and page 5 post # 117---- .. the sub rear cab mounts are narrower than a truck, so you could either get truck ones, and modify them to fit, or use some construction paper (thick paper) and make a pattern off what is left of your old ones, and then bend them up yourself, or take the pattern to a sheet metal shop and have them bend it up.
