Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-27-2003, 11:39 PM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
WTB 6.2 diesel oil cooler lines
I have a 87 k30 with a 6.2 Diesel and the oil cooler lines leak. I have to look to see which one, but seem like they would be pretty much tossed out by most people, so maybe I could just get both of them. These are the lines that go from the back of the engine to the radiator.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 08-29-2003, 10:16 PM   #2
TROYLV
oil lines
if you can pull them out and send them to me, i can make you a set. cost would be materials only. i have the flare tool and the benders. the price of tubbing is the most expensive part of them.
if you have a hyd hose supplier where you are they can make them also. they usualy only charge for the materials also.
troy wilson
TROYLV is offline   Reply With Quote
