Old 03-23-2015, 09:27 PM   #1
ClassicGuy
Electric fans question
So I am installing two electric fans on my 70 C10. Is there a specific way to mount them? Meaning should I mount them on the front or rear of the radiator? I'm thinking since the original fan and shroud were behind the radiator, that maybe I should mount them there. By front I mean behind the grill and behind I mean in front of engine. Any help would be greatly appreciated. Thanks
ClassicGuy is offline   Reply With Quote
Old 03-23-2015, 09:36 PM   #2
flashed
Re: Electric fans question
It will depend on which fans you have ,pusher (outside radiator) or puller (inside toward the motor) .
flashed is offline   Reply With Quote
Old 03-23-2015, 10:28 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Are you overheating? Do you need more air across your radiator? Does your factory fan fit into the shroud properly (by that, I mean the blades are approximately half and half into the shroud, so that they actually pull air from the radiator). Is the radiator clean inside and out? I agree with the fact the type of fan decides the place of mounting them. Pusher fans are not as effective as puller type fans, but if you are keeping the factory fan and shroud, then you need to get pusher design and mount them directly in front of the radiator. However, the fan itself now becomes a small bit of a restriction on the radiator air flow, if they are not running.
Frank
piecesparts is offline   Reply With Quote
Old 03-23-2015, 11:46 PM   #4
ClassicGuy
Thanks guys. The engine is new and tge radiator is a brand new aluminum radiator. So is it better to get a pull type fan rather than a push one in my case?
Old 03-23-2015, 11:51 PM   #5
Lurayfarmer
Lurayfarmer's Avatar
Under those circumstances, what are the fans for? The factory setup is more than adequate with a fresh radiator. The electric fans would only be of use if you planned to sit in traffic in hot weather with the AC on.
Shenandoah Valley of Va
1972 GMC 2500 Sierra Grande
402, Custom Camper Package
Lurayfarmer is offline   Reply With Quote
Old 03-24-2015, 12:01 AM   #6
ClassicGuy
Great point! Thanks for that
Old 03-24-2015, 08:55 AM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: Electric fans question
Puller fans are much better at cooling than pusher fans.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-24-2015, 11:13 PM   #8
piecesparts
From past experience, I am not sure as to why you are looking for electric fans and with plans to keep the factory fan. I have changed out my trucks to electric fans and eliminated the belt driven fan on some of my trucks. I gained some benefits from that change out, but I did not keep both sets of fans. Attached are pictures of an 84 GMC with dual electric fans and also a 91 Silverado with the same set of fans. Both change outs were very similar and I never had any cooling issues after the modification.
Frank
