03-24-2015, 05:45 AM | #1 |
Wiring Harness Info.
Does anyone have any information or a schematic on a RPC (Racing Power Company) wiring harness model R1002.
I got a very good deal on it at a swap meet this last weekend. It is a GM column type and has 21 circuits. I know I don't need anywhere that many but it was just too good of a deal. Only thing was the documentation was very limited. I've looked on line and found some stuff and can figure it out eventually but thought I'd check and see if anyone had any info on hand for quick reference. Thanks in advance Ron
Kodiak's 53S10 Build |
03-24-2015, 11:41 AM | #2 |
Re: Wiring Harness Info.
Use the EZ 21 circuit wiring harness manual. They are basically the same. You'll go crazy trying to find one for the RPC. I never did. Used the EZ and it worked
03-24-2015, 12:36 PM | #3 |
or painlessperformance.com not sure you can download manuals from ez wire
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-24-2015, 01:15 PM | #4 |
My bad Ogre. I believe I got the EZ wiring manual off the Speedway site. I'll check
03-24-2015, 01:21 PM | #5 |
ok, google "ez wiring harness instructions". It gives you the 12 circuit diagram, or use the painless. They are basically the same
03-24-2015, 11:14 PM | #6 |
Thanks Guys that is just what I was looking for.
(I did try RPC with no luck what so ever)
03-24-2015, 11:45 PM | #7 |
Just printed out the Painless Manual, it will be a great help. Thanks again everyone
03-25-2015, 12:50 PM | #8 |
i used both the ez wire and the painless manuals when i wired truk with ez wire
take notes of any modifications right in the manual and draw up anything added cut a wire, make a note. add a relay, make a drawing. staple everything together when your done, it makes for easy work later
03-25-2015, 01:50 PM | #9 |
I went one step farther, because of the Frankentruck nature of mine. I copied the ez diagrams and put them on a sheet of large paper, in the location they go in the truck. I added the GM column diagram and information off of the original stock wiring that was remaining. I completed the circuits between all the parts and kept good notes as I went so I can figure out what I was thinking. Since the wires are labeled and I used some for other purposes I also noted that. I then laid out the harness over the diagram and reconfigured the main runs (front, engine compartment, dash and rear) to match the diagram. I also figured out where I wanted quick connects (I used trailer connectors) for ease of install or future tear down. Started running the main runs, back, engine, front and dash in that order. I found keeping the fuse box mount under the dash loose until all the wires were run helped. Once the mains were ran I started completing each individual wire in each circuit. So far I only found 1 additional circuit I had to run after the fact. Details of my build are in the build thread starting at post 770. I had the advantage of my OCD grandaughter Brit to help keep things in order, neat and organized!
http://67-72chevytrucks.com/vboard/s...&postcount=770
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
03-25-2015, 11:13 PM | #10 |
Excellent advice! Thanks
