Old 03-24-2015, 10:50 AM   #1
revjames
Help Buying Brake Line kit
I need help from the gurus on here. I have been looking through the forums but can't get an exact read on what I need. I have a 63 swb fleetside c10 and it has a 71 rearend and a 85 frontend. Would the brake line kit from classictruck.com for 63 disc to manul drum be the setup I need for the prebent lines? Thanks for the help
revjames is offline   Reply With Quote
Old 03-24-2015, 11:15 AM   #2
T and S
T and S's Avatar
Re: Help Buying Brake Line kit
IMO - I would call whoever you want to order the brake line kit from, and tell them the mods you have done to your truck. They can probably bend you up something to fit your truck or recommend to you what you should do.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 03-24-2015, 09:38 PM   #3
sixTsix
Why not get a roll of Nicop brake line and run them the way ya want?. It imo cheaper and easy to do
I bought a prebent line kit for my conversion and ended up not using a lot of it. I ended up getting a rol of Nicop and running the lines the way I wanted them
66' Short Stepper- 350-NP440/4speed
Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426
sixTsix is offline   Reply With Quote
