Old 03-24-2015, 06:41 PM   #1
lovemmth
lovemmth's Avatar
drum to disk
Hi all I have a 65 lwb c20 that a few years ago I swapped out the suspension to a 67 6 lug 1/2 ton front and rear. My problem is not knowing at the time I should have gone to front disks (Im ok with 6 lug). Returning to the junk yard what year donor truck should I look for? And am I going to need arms and all or just spindle and rotors.
lovemmth is offline   Reply With Quote
Old 03-25-2015, 06:41 AM   #2
PGSigns
PGSigns's Avatar
Re: drum to disk
Here is a thread that will give you everything on doing the drum to disc swap. I used everything but the cross member from a 78 under the 66. Used rotors from Summit to keep the 6 lugs.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
