Old 03-24-2015, 11:07 PM   #1
zibs71
zibs71's Avatar
71 c-10
I have a 1971 C -10. Since I've owned it (almost 4 yrs) the speedometer has never worked. Well with my interior almost complete ( ya I know should have prolly fixed that first) All gauges work except speedometer. Was this issue in that particular year or? Aside from speedometer cable I wouldn't know where to start. Any ideas?
350
Th350
no A/C
I appreciate all feedback
zibs71
zibs71 is offline   Reply With Quote
Old 03-25-2015, 07:26 AM   #2
daily_danger
Re: 71 c-10
Pull the cable out of the tranny and verify the plastic gear isn't broken. Shine a light and check the gear on the output shaft. Its a good time the change the seals too if you haven't.
daily_danger is offline   Reply With Quote
Old 03-25-2015, 08:21 AM   #3
Andy4639
Old member
Andy4639's Avatar
Question Re: 71 c-10
Take the cable loose at transmission and hook the cable to a battery drill and see if the speedometer will work. If so then it's something inside the transmission.
If it doesn't work then either the cable is bad are the speedometer is bad.Just bump the drill the first time to make sure the rotation is right.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-25-2015, 08:28 AM   #4
bigmac73
bigmac73's Avatar
Re: 71 c-10
things just wear out in 40 some years, nothing new....
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
